Help ... Glazing Issue - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-05-2010, 01:52 PM   #1
help ... glazing issue
I had some steel casement windows glazed at the beginning of Sept this year. The putty used was an oil based putty of a gray color which I was told was specifically for steel casement windows. Now, barely 2 months later the putty is cracking and the company that did it says the problem is that we didn't paint it to seal it. I've never seen glazing putty painted before and didn't know that sealing was required. I'm wondering if that is standard practice today and I'm just out of touch or is that just an excuse. Any comments?
FWIW, my current house, built in the '50s, uses aluminum single-hung windows and the putty in those windows has never been painted. Of course the putty is cracked now ... but it's been more than 50 years. thanks
Peyton
peyton is offline   Reply With Quote
Old 11-05-2010, 07:56 PM   #2
Rewards Points: 5,336
The glazing compound should have been painted. Was it?
Ron
Old 11-06-2010, 11:08 AM   #3
Ron
No. Nobody ever mentioned that it should be painted. As per the initial post, it is news to me.
Who should have painted it? The glazier or someone else? thanks for responding.
Peyton
Old 11-06-2010, 11:19 AM   #4
40+yrs Paint Trades
Peyton
Glazers ain't painters. You should have painted it, or hired a painter. Glazing is always painted when the window is painted. Maybe the glaziers thought the windows were going to be painted?
How cracked is it> Is it falling out? You might be able to rescue the job.
hoz49 is offline   Reply With Quote
Old 11-06-2010, 09:11 PM   #5
The windows were galvanized so they would never have to be painted. The glaziers never mentioned painting ... probably assumed it was a given.
The cracks are across the putty line, i.e. perpendicular to the frame. Thanks
Peyton
Old 11-07-2010, 06:29 AM   #6
40+yrs Paint Trades
If they are minor cracks you might be able to fill them with paint. Be aware when painting a window, ideally, the paint should extend just a hair above the glazing, onto the glass to provide a seal.
If the cracks are wider, or the glazing is so dry it's falling out, you probably have to re do some. Sometimes fresh glazing can be cut into the cracks only if the adhesion of the original is sound.
window glazing Gatorgirl1 Painting 7 08-04-2009 02:23 PM
Interlock Paver Issue cbadrik Landscaping & Lawn Care 2 07-27-2009 07:29 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 03:14 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
Fireplace framing/tile issue robdville Building & Construction 13 11-14-2008 07:14 AM
