Help A Girl Out? Window Replacement With Steel Siding - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-07-2009, 08:03 PM   #1
help a girl out? window replacement with steel siding
we need to replace some windows and we have steel siding. without spending all summer on 3 windows, what can we do?
indynile is offline   Reply With Quote
Old 03-07-2009, 08:16 PM   #2
Remodeling Contractor
use replacement windows not windows designed for new construction. These will fit inside the existing frames of your current windows. Remove the window stops remove the window frame and add new replacement window frame.
Old 03-07-2009, 08:41 PM   #3
i would love to, but the frame itself appears to be rotten. apparently they (the previous owners) resided over old wood windows and now moisture and mold are a huge problem. or, maybe there is options with this that i am not aware of
Old 03-07-2009, 11:14 PM   #4
Retired from the grind
gregzoll's Avatar
Rewards Points: 5,882
In that case, there is no option other then be prepared to spend some time tearing off the siding and doing it correctly, with a new siding job.
gregzoll is online now   Reply With Quote
Old 03-08-2009, 02:12 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 682
You dont need to rip off any siding. What you will need to do however,is cut it back to allow you to completely remove the old window and properly install and flash the new one. Then finish off the exterior with some new trim (larger to fill the new space). You can cap it with aluminum, or install a trim board made of cedar or a composite---whatever matches the rest of the house.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 01-30-2012, 09:13 AM   #6
what do you use to cut the steel siding? I have the same problem, the frame itself is shifting and allowing air leaks.
frankwl is offline   Reply With Quote
Old 01-30-2012, 09:22 AM   #7
Too Short? Cut it Again!
If I had a rot issue that might be hiding at least somewhat under siding, I would pull it off for a look before fitting new windows. You cannot flash over rot and expect much long term. Bite the bullet. Do this right. It will only get more expensive if you do not.
Old 01-30-2012, 01:41 PM   #8
Rewards Points: 1,014
Frank: To cut the siding, one option is to get a C6 carbide blade, the finest teeth you can get, and install it in your "Skill" saw, like any other blade. These blades are made specifically to cut steel and cut like a mad mutha. (Edit): I have never cut siding w/ one, per se, but have cut plenty of sheet metal. Try the blade on a scrap (like your neighbor's house) before you hit your house w/ it. I don't know how thick siding is, and whether or not it will tear instead of cut. If you do this, pls post what happened. Thanks.
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Vinyl Window Replacement aschau01 General DIY Discussions 2 12-23-2008 06:17 PM
Adding a window - cutting through Aluminum Siding -how to repair siding to look good? DyerWolf Building & Construction 6 12-22-2008 05:02 PM
Replacement Window - Nail Fin Question smoenra General DIY Discussions 12 09-04-2008 11:19 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
