Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-09-2009, 03:54 PM   #1
Question
Help: Garage door meeting uneven concrete pad
My garage floor is pretty uneven where the garage door meets it. In the middle of the door, it hits the floor fine, but on either end, the ground slopes down. This basically creates two triangular gaps on either end. Starting from the edge, the gap is about 2.5inches and it takes roughly 2.5 feet until the floor is level with the center. Naturally, the gaps are well traveled by the local mice hordes and I have become the angel of death armed with glue traps. This is not fun and some of them seem pretty adept at avoiding them now.
I have tried many poorly rigged solutions that have all failed miserably. At this point, I am ready to do what it takes to solve the problem right and (hopefully) forever.
I'm assuming that I will probably need to use some kind of concrete patch material to "shore up" the gaps, but I am not really sure the best product to use or the best application method for my situation. Currently, there is a layer of paint over the concrete, so I imagine that will need to come off before I put down the patch - any advice on the easiest way to prep the surface and patch would be greatly appreciated.
Also, I am open to other "out of the box" solutions.
Help?
sodade is offline   Reply With Quote
Old 02-09-2009, 04:43 PM   #2
Old School
Willie T's Avatar
No, no, and No, again on attempting such a small concrete patch with feathering edges. It will never hold.
If anything, I would see if I could simply screw on a piece of 2.5' sheet metal to the side of the door on both ends. Putting it on the front side would effect the best (sealed against the wall) fit, but it would look cleaner on the inside. Install it when the door is closed to make sure you fill the gaps fully... it may need to have a little grinder and file work to achieve the proper fit against the floor.
Willie T
Old 02-09-2009, 05:00 PM   #3
gravity always wins
I agree with Willie's theory, but what I've done was use treated lumber and cut tapered strips that were scribed to the floor. Then bolted them to the bottom of the door. They're less likely to get bent.
Old 02-09-2009, 05:36 PM   #4
Remodeling Contractor
I agree with that one. Just scribe a filler from a pressure treated 2x4 and screw it in. Then flash it with aluminum coil for a cleaner look and to help any water getting into the seam. use polyurethane glue along with those galvanized screws.
Old 02-09-2009, 06:36 PM   #5
And perhaps a sharp lower edge to decap the mice
Chemist1961 is offline   Reply With Quote
Old 07-09-2012, 08:40 PM   #6
Help?
We used a snirtstopper to fix the gap problem we were having between our floor and door. They say it keeps out the rodents too. Check out their website, snirtstopper, it sounds like exactly what you need.
COACH BOB is offline   Reply With Quote
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 11:51 PM
double car garage slightly uneven... mcvane Building & Construction 6 11-25-2007 09:41 AM
Building garage with elevated concrete floor dmj245 Building & Construction 13 05-31-2006 05:13 AM
Garage Concrete Slab...HELP? Aqua-Man Building & Construction 2 06-17-2005 02:11 PM
