Help!! Drill Bit Stuck In Door - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-21-2007, 02:32 PM   #1
Help!! Drill bit stuck in door
Any idea how to remove one? It's flush with the door, will spin around but you can't grip it. Thx
starente is offline   Reply With Quote
Old 01-21-2007, 02:39 PM   #2
I have had a bit of luck using a drop of Super Glue on the end of another piece of metal rod (perhaps the rest of the drill bit) and hold it long enough to set up. Then use it to twist and pull the broken section out. Good luck.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 01-21-2007, 02:44 PM   #3
Is this on the front edge of the door or the side?
redline is offline   Reply With Quote
Old 01-21-2007, 02:47 PM   #4
Thanks!
Thanks for the quick reply. I was asking for my b/f but I just went up to take a look and was able to get it out myself in about 3 minutes
I used a pair of pliers for electric work that had a sharp, tiny tip and it came right out. A woman's work is never done!
Old 01-21-2007, 02:53 PM   #5
Tell him to keep his bit away from where it doesn't belong.
French Doors from Homedepot or Lowes??? johnnytuinals General DIY Discussions 47 01-10-2009 11:00 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
