-   -   Help!! Drill bit stuck in door (http://www.diychatroom.com/f2/help-drill-bit-stuck-door-6045/)
starente 01-21-2007 02:32 PM
Any idea how to remove one? It's flush with the door, will spin around but you can't grip it. Thx:eek:
majakdragon 01-21-2007 02:39 PM
I have had a bit of luck using a drop of Super Glue on the end of another piece of metal rod (perhaps the rest of the drill bit) and hold it long enough to set up. Then use it to twist and pull the broken section out. Good luck.
redline 01-21-2007 02:44 PM
Is this on the front edge of the door or the side?
starente 01-21-2007 02:47 PM
Thanks!
Thanks for the quick reply. I was asking for my b/f but I just went up to take a look and was able to get it out myself in about 3 minutes :laughing:
I used a pair of pliers for electric work that had a sharp, tiny tip and it came right out. A woman's work is never done! :wink:
redline 01-21-2007 02:53 PM
Tell him to keep his bit away from where it doesn't belong.:jester:
