Help With Dehumidifier Location!! (weep Holes?) - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-20-2013, 12:20 PM   #1
Rewards Points: 18
Help with dehumidifier location!! (weep holes?)
Hello, my basement is partitioned into two sides. Ones side is semi finished and the other is not. The side that is semi finished has the dehumidifier in it but the other side of the basement has the sump pump.
I am tired of draining the water bucket for the dehumidifier every 4 days. The problem is if I put the dehumidifier in the room with the sump pump, the semi finished side stays too moist.
Is it suitable to run a dehumidifier drain tube into the wall on the semi finished side where the waterproofing system was installed years ago? I could drill through the plastic at the bottom and feed the drain tube into one of the weep holes drilled into the cinder block.
Is this suitable for allowing the drain to to drip into that channel or am I asking for problems?
I can't see too many other alternatives...
ryanatw is offline   Reply With Quote
Old 04-20-2013, 12:47 PM   #2
Too Short? Cut it Again!
As long as the sump is downhill all the way from the dehumidifier, why not just drill a small hole through the wall and run tubing to the sump? I would want to be able to keep an eye on it and not hide it in the wall.
Water from weep holes in vinyl siding? JayBird Building & Construction 9 01-24-2013 03:01 PM
Whole-house dehumidifier installation? mahohmei HVAC 0 11-26-2012 09:42 AM
How to best cover weep holes on a brick wall smcmurrey General DIY Discussions 27 10-12-2011 11:33 PM
What Can You Put in Weep Holes to Keep Bugs Out! limitdiy Building & Construction 9 07-01-2010 11:42 PM
Alternatives for fixing holes in tile roof felt Squash_Pro Roofing/Siding 4 05-13-2010 07:20 PM
