Help! Building Crack - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-27-2011, 10:39 AM   #16
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 822
I'm a little horrified that you're doing research for a college project on an internet chat room.
Please go to the library and research this book:
Geotechnical and Foundation Engineering: Design and Construction
Robert W. Day
McGraw Hill, 1999
Chapter 7 has some good information on cracking, and has even more resources annotated throughout. But regardless, don't lie. I'm almost half tempted to let you in on the joke interpretations sprinkled in the suggestions so far, but you should research it all and get solid sources yourself before you look like a fool when you turn your paper in.
Aggie67 is offline   Reply With Quote
Old 04-27-2011, 11:22 AM   #17
A Little Of Everything
Rewards Points: 1,364
Robert W. Day
McGraw Hill, 1999
Believe me, many college students think that "copy & pasting" from websites qualifies as research & writing.
DrHicks is offline   Reply With Quote
Old 04-27-2011, 03:29 PM   #18
Originally Posted by oh'mike View Post
FTW---you would get better responses if you offered your own solutions
and let us tell you if the solutions are correct or not.
How are you going to rectify the bottom picture?---Mike---
I think i will be using "Crack injection with epoxy" ?
ConstructionFTW is offline   Reply With Quote
Old 04-27-2011, 03:39 PM   #19
Robert W. Day
McGraw Hill, 1999
No, beleive me I'm not going to write everything which is disscussed here. I went through many sources (almost finished the report) but I had some doubts about the reason behind the cracks which i couldn't understand thats why i came here to ask to clarify it to myself.
anyways thanks all !!
Old 04-27-2011, 07:38 PM   #20
Rewards Points: 276
Robert W. Day
McGraw Hill, 1999
Actually there is a lot more information available online that there is in any library. Internet sources are perfectly acceptable as long they are verifiable and you site your sources in the correct format (APA,MLA). The book suggestion sounds like a good one though.
As far as the second crack solution I would guess you would need to resolve the footing issue unless it has stabilized then you could seal the crack with hydraulic cement.
Jim F is offline   Reply With Quote
The Following User Says Thank You to Jim F For This Useful Post:
oh'mike (04-27-2011)
Old 04-27-2011, 07:57 PM   #21
DIY staff
Rewards Points: 7,174
Jim's right---If you epoxy that crack without strengthening the footings another crack will appear elsewhere.
Old 04-28-2011, 04:26 AM   #22
Mike and all Thanks a lot.. You guys rock
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 04:04 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Effect of Heat Load of Tenants on a Commercial Building mphoenix HVAC 1 04-20-2011 03:59 AM
Siding on utility building Angela3511 Building & Construction 5 04-18-2011 07:28 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
