Help! Building Crack - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-25-2011, 12:49 PM   #1
Help! Building crack
all done
ConstructionFTW is offline   Reply With Quote
Old 04-25-2011, 07:02 PM   #2
Rewards Points: 5,336
Looks like earthquake damage.
The first one, maybe a mortar.
Get it. A masonary joke.
Ron
Old 04-25-2011, 07:07 PM   #3
DIY staff
Rewards Points: 7,174
Damage caused by failure to provide expansion space against poured concrete roof.
Roof is pushing parapet walls.
Just a guess--do I win a prize?--Mike---
Old 04-25-2011, 07:26 PM   #4
kwikfishron's Avatar
Rewards Points: 86
There's no more roof, mortar fire imploded it causing the damage on the corner.
Luckily though most of the gunner ports are still useable.
kwikfishron is online now   Reply With Quote
Old 04-25-2011, 07:45 PM   #5
DIY staff
Come on back new guy---that second picture --the cause is is obvious that I'm going to let Kwikfishron answer that one--
Old 04-25-2011, 07:56 PM   #6
Rewards Points: 86
Well thank you Mike, the second picture looks like Termites to me.
Old 04-25-2011, 08:10 PM   #7
DIY staff
I would have had it wrong--
I figured one mason started on the left--another from the right---one guy used less mortar--
They didn't think any one would notice --so they left it like that.
Old 04-25-2011, 08:21 PM   #8
Rewards Points: 86
Glad I could help.
Old 04-26-2011, 06:53 AM   #9
Ok thanks a lot guys. The second pictures is caused by termites, I got it.
What about the first picture? I know it's not caused by earthquake as earthquakes are not so common in the place where i live. so please just give a few explaination about the first pic so i can write about it in the report.
kwikfishron, oh'mike and Ron6519 thanks a lot.
Old 04-26-2011, 08:13 AM   #10
DIY staff
My answer was correct on the first picture---concrete roof expanded and pushed out blocks--
Second picture---footings dropped.
Old 04-27-2011, 04:48 AM   #11
Thanks a lot sir. One more question please:
what are the CRACK REPAIR METHOD for this kind of cracks as you can see in the first picture?
Old 04-27-2011, 06:44 AM   #12
Stay-at-home GC
A mortar
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
The Following User Says Thank You to CplDevilDog For This Useful Post:
ConstructionFTW (04-27-2011)
Old 04-27-2011, 08:31 AM   #13
DIY staff
Remove the parapet--add expansion material along slab--(foam or fiber mat) then rebuild parapet.
Old 04-27-2011, 08:34 AM   #14
DIY staff
FTW---you would get better responses if you offered your own solutions
and let us tell you if the solutions are correct or not.
How are you going to rectify the bottom picture?---Mike---
Old 04-27-2011, 08:57 AM   #15
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Slap some parging cement on it, put it up for sale and hope it sells before winter.
The Following User Says Thank You to Red Squirrel For This Useful Post:
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
Effect of Heat Load of Tenants on a Commercial Building mphoenix HVAC 1 04-20-2011 04:59 AM
Siding on utility building Angela3511 Building & Construction 5 04-18-2011 08:28 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
