#1 |
STAFF
Heavy Duty Casters
Does anyone know if the 4" heavy duty cast iron castors from Harbor Freight would work on a roll around for a unisaw base. I have small castors on the base now but it would take a truck to push it around.
If the HF castors won't work does anyone have any suggestions?
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Jim |
#2 |
Super Moderator
Heavy Duty Casters
I've used the rubber tire HF casters under some extremely heavy loads and they have worked well--the iron ones should do well for that saw--
I have them under an antique grand piano (hobby fixer upper) they work just fine---Mike---
New members: Adding your location to your profile helps in many ways.--M-- |
#3 |
STAFF
Heavy Duty Casters
Thanks Mike I really appreciate you.
#4 |
Super Moderator
Heavy Duty Casters
For the money they are really good---I use them for tile dollies,too.
#5 | |
STAFF
Heavy Duty CastersQuote:
Sometimes I wish my Unisaw was shorter but I just can't bring myself to cut it down, so maybe with good castors I can move it out of the way when not using.
#6 |
Super Moderator
Heavy Duty Casters
Wheels under the tools sound like a plan---I don't know about rolling around a saw---I spend good money for wheels under mine--and it has never been moved since the day I set it up.
I have a big un'. 7 feet wide and almost 7 feet across---(Young folks--big is better --)--Mike--
#7 |
Heavy Duty Casters
After thinking out loud one day, a few buddy's told me that it would never work, but I have had my old Coats tire changer on casters for 10-15 years now, and it works great. Obviously not the same thing, but somewhat comparable when you consider the pushing, pulling, turning, etc. that goes on. Currently, my table saw is setting on a solid 2x4 frame with a dust collector, shelves, hook, etc. that I rather hastily put together a good many years ago. I have a set of steel wheels on the front that miss the floor by about 1/8", so to move it I have a slot over the dust catcher where I slide a 2x4 in, and when I lift up the back, the wheels touch the floor, so I can roll it like a one handled wheel barrow. Fortunately, I don't have to move it a lot, but often enough that I have decided it's too much work, so I have just recently started laying out a new cabinet, with 4 casters, which I plan to finish over the winter. Like you, Jim, I'm going for as many things on casters as I can.
#8 |
STAFF
Heavy Duty Casters
Good gravy Mike, you do have a huge saw, I thought mine was big but it is just wide. At one time I had a shop 50'X100' now that I retired I have 12'X18", I need to do something, I can't move around out there.
Dexter, that is good thinking the way you fixed up your machine, I wish I could fix mine that way but I am just not strong enough anymore to move it like that. I want to put wheels as big as I can so it will roll over things on the floor. I sold both of my dust collectors so there is dust on the floor a lot. That is one thing I wish I hadn't sold but there just wasn't room in the shop for one of them. I appreciate y'alls help a lot.
#9 |
Super Moderator
Heavy Duty Casters
You sure do need everything on wheels. And hopefully a paved area in front of the building.
I think those casters will roll over the crumbs---a small dust system might be a good idea. My saw has a 54" rip fence --plus and extra extension on the left--and a 4 x 7 outfeed table. About the size of a king size bed---
#10 | |
STAFF
I have the 54 inch rip fence on my saw also and with the miter saw at the end of the table saw against the wall there is just enough room to squeeze by I can't rip a sheet of plywood in half the long way on the table saw, well I couldn't even if I had the room, handling full sheets of plywood are over for me.I see some of the fellows shops on the board here and drool, I love the way they have their shops set up, hopefully I can set mine up like that. Believe it or not, I have built full sets of kitchen cabinets in that small shop, wasn't easy but doable.
#11 |
Super Moderator
Heavy Duty Casters
So many people end up doing nothing because they don't have 'the ideal' set up.
I've made some mighty fancy stuff over the years with all the wrong tools-- I made so many raised panels on a job sight router table that I wore a grove into the sheet of particle board. The tools don't make the craftsman--that's for sure---
#12 | |
STAFF
Back when we were doing business wide open, there wasn't time to stop and build a router table. I took a piece of 3/4 plywood and bought a 1/4 piece of aluminum and made a set up that I could just clamp to a table or anything stable. I did have to add 1X6 to the bottom to stiffen the plywood up but it worked and I still have it and use it. I just never got around to building a nice router table.
#13 |
Super Moderator
Heavy Duty Casters
I watched a carpenter screw a Skill Saw to the bottom of a sheet of plywood to make a quick 'table saw' once---worked just fine--
I learned trim with a miter box and back saw---hammer,nails and a punch--It's what every one did . I was drilling and hand nailing maple stair treads the day another carpenter dragged over a hose and said," Here give this a try. You might like it." Nail guns!!! Oh,boy what an invention!!!
#14 | |
STAFF
#15 |
Super Moderator
Heavy Duty Casters
I got my first router in exchange for doing some work---I've loved routers ever since.
They are a magic tool that turns plain into fancy--- I carry two cases filled with bits to every trim job---Those boxes make a guy look like a wizard to the customer---
| The Following User Says Thank You to oh'mike For This Useful Post: | BigJim (12-23-2011) |
| Display Modes | |
| Heavy Duty Tools/For a Woman's Hands | Sheila4467 | General Discussion | 8 | 11-07-2009 03:30 AM |
| Need super heavy duty Plant poison. Help. | gante | Landscaping & Lawn Care | 8 | 09-01-2009 01:05 PM |
| I can't find 16 gauge heavy duty extension cord! | darsunt | Electrical | 21 | 08-04-2009 08:50 PM |
| Heavy Duty Tapcons | terri_and_jj | Building & Construction | 1 | 02-24-2008 02:25 PM |
| Heavy duty garage shelving suggestions | feign3 | Carpentry | 1 | 09-20-2007 11:07 PM |
