Heating Zone Heats Some Unused Rooms - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-08-2004, 04:34 PM   #1
Heating zone heats some unused rooms
Hi,
I have a oil-fired boiler that heats three zones using hot water radiators.
One zone heats the basement, kitchen and living room. There is no real need to heat the basement. Is there an easy way to reduce the amount of heat radiated by the radiator in the basement?
My first thought was to stuff heat resistant insulation in the radiator. Another option is to remove the fins from the hot water pipe that runs inside the radiator (that's a destructive option I don't care for).
Thanks!
ChessMan is offline   Reply With Quote
Old 11-09-2004, 08:19 PM   #2
Originally Posted by ChessMan
Hi,
Thanks!
turn the vavle down that's on the side of the radiator you want to turn the hard down on. If you shut the valve off totally the radiator won't heat up at all. baseboard heating runs in a loop. But radiator type boilers heat up individually.
Hammertime is offline   Reply With Quote
Old 11-10-2004, 01:36 PM   #3
I'm sorry. I was using the wrong terminology. I have baseboard heaters that are running in a loop.
