Heating A Small Outside Toilet - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-14-2011, 02:03 AM   #1
heating a small outside toilet
Hi, I have a small brick built outside toilet that is joined onto my house, there is no electric plug sockets but there is a light fitting, the room size is 3 feet x 5 feet x 8 feet, trouble is it gets very cold in there so I am looking at ways to heat it. I thought about an infrared bulb or heat bulb but I am unsure if there is such a thing, what are my options to provide heat in this room.
khampson is offline   Reply With Quote
Old 11-14-2011, 02:42 AM   #2
Thadius856's Avatar
Rewards Points: 504
The hobo way would be to use a receptacle light socket adapter and an electric space heater. I don't think you can beat the fast warm up time of an electric heater, and you probably wouldn't want to keep it heated 24/7. If the light is remotely switched, you could also heat it up before going outside.
However, I'm not convinced that would be safe to draw that much wattage from a light socket or to leave it unmonitored.
Have you considered radiant heat flooring or a heated toilet seat? I assume the space is insulated well.
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 07:41 PM
Compact elongated toilet for small bathroom? wcb22 Remodeling 1 01-20-2011 08:41 PM
Compact elongated toilet for a small bathroom? wcb22 Plumbing 3 01-19-2011 10:07 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
How easy to install hydronic heating in small bathroom mayhem69 HVAC 9 10-25-2009 03:56 PM
