heating a small outside toilet
Hi, I have a small brick built outside toilet that is joined onto my house, there is no electric plug sockets but there is a light fitting, the room size is 3 feet x 5 feet x 8 feet, trouble is it gets very cold in there so I am looking at ways to heat it. I thought about an infrared bulb or heat bulb but I am unsure if there is such a thing, what are my options to provide heat in this room.
Keith |
The hobo way would be to use a receptacle light socket adapter and an electric space heater. I don't think you can beat the fast warm up time of an electric heater, and you probably wouldn't want to keep it heated 24/7. If the light is remotely switched, you could also heat it up before going outside.
However, I'm not convinced that would be safe to draw that much wattage from a light socket or to leave it unmonitored. Have you considered radiant heat flooring or a heated toilet seat? I assume the space is insulated well. |
| All times are GMT -4. The time now is 05:32 PM. |
