Heat Issue - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-28-2010, 08:16 PM   #1
Question
Heat issue
Heat came on this morning but now won't. I can hear the thermostat click on and off but nothing happens. What can I check myself?
chrisf is offline   Reply With Quote
Old 12-29-2010, 01:53 AM   #2
Rewards Points: 1,092
It may be obvious, but.... (Assuming a petrol boiler).... boiler plugged in? (I knocked my outside freezer plug lose last year while working in that room, and did not notice it till I smelled bad meat. Lost 100 lbs of moose, halibut, and some domestic stuff. Stink happens.) If so, hit the reset button on the boiler. Sometimes FM happens, too. Out of fuel? (Deliveries don't happen, and people steal fuel.) Water in the fuel line? (Check fuel filter.) Loose wires anywhere? Poke around and maybe you'll see something obvious.... I hope. I hate it when boilers go dead.
Old 12-29-2010, 08:05 AM   #3
Rewards Points: 5,336
It would help if you supplied a detailed post of the equipment you have as the solutions vary from furnace to boiler to heat pump.
The obvious:
Breaker popped?
Oil tank dry?
Switch turned off?
Ron
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
how does a controlled heat transfer work? Red Squirrel HVAC 8 09-25-2010 04:04 PM
Need help with heat and hot water issue Spydey HVAC 50 03-07-2010 08:46 PM
Which honeywell thermostat should I buy for my Carrier heat pump? mannypp HVAC 29 01-30-2010 02:21 PM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 03:23 AM
