Heat Ducts - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-22-2009, 04:13 PM   #1
Rewards Points: 119
Heat ducts
The heating vents in our new home are in our floors. While recently cleaning them out I found about 1/2 inch of dirt in view in the front room vents. While vacuuming both lengths of the ducts as far as I could reach with the vacuum hose (3-4 feet) I could hear that a lot of dirt was being sucked up. Is there an explanation for this. I expected a pile of dirt under the opening and some dust in the ducts but not a pile of dirt in the ducts.
debd is offline   Reply With Quote
Old 06-23-2009, 06:00 AM   #2
A lot of stuff gets into ducts during construction, and often never gets cleaned out. And running the system without a filter will add dust, animal fur, ect. You must be the first to clean your ducts.
Old 06-23-2009, 07:55 AM   #3
Registered User
Termite's Avatar
Agreed, sounds like either residual construction debris or a lack of maintenance. Just have them professionally cleaned and keep a clean furnace filter in the unit and you shouldn't have problems.
Old 06-23-2009, 10:10 AM   #4
Rewards Points: 119
Thanks for the information. Having that dirt blowing around the heat ducts all these years sound gross
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
adding heat ducts to existing plenum milcurt HVAC 4 01-13-2009 07:52 PM
Romex and heat ducts handifoot Electrical 8 04-13-2008 08:50 AM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 12:47 AM
