Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-23-2009, 10:43 PM   #1
Header span?
I have two openings that I need headers in:
10ft opening none bearing. Can I use (2) 2x8
5ft load bearing, one story ranch. 2 x 8 also?
Please answer asap. Thanks
beaver7 is offline   Reply With Quote
Old 02-23-2009, 10:58 PM   #2
Old School
Willie T's Avatar
Header span?
There are span tables for this you can look up, but here is an old standby that is pretty much on the safe side.
A traditional rule of thumb often used to size headers is the "inch per foot" rule which will provide adequate strength in most cases with spans up to eight feet. For headers in single story dwellings supporting no point loads such as posts or beams, provide one inch of header depth for every foot of header length, min. 4 x 4.
Willie T
Old 02-24-2009, 06:50 AM   #3
Remodeling Contractor
Header span?
Keep in mind that much more must be considered. What and where is the roof load. Best not to be guessing on this. Lumber yards can give this info since they have engineers to determine beam sizes. Ask for the correct laminated beam and they can tell you that a 2X10 can be used
Max span for 4x8 header? MusicMan_234 Building & Construction 2 05-29-2008 01:17 PM
Garage Header Insight red3908v Building & Construction 4 04-27-2008 09:55 AM
Header Span Table cahardesty Building & Construction 1 01-22-2007 10:45 AM
Moving Header Supports Star Building & Construction 3 09-25-2005 01:50 AM
