Header Advice Needed! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-26-2011, 08:59 AM   #1
Header advice needed!
Ok, the specifics are:
2 story CH colonial on a slab, I have a 17 foot load bearing wall in the middle of one side of the house which is holding up the 2nd story floor but no walls directly above so no roof load. The wall is carrying a span of about 26 feet from the front to back of the house. I want to remove as much of the wall as possible without getting into breaking the foundation to pour footers for lally columns. I would like to use 2- 2x12's supported by 3 or so cripples on each side. Can I go 10 or 12 feet? I wouldn't mind buying a pre-made LVL or Flitch beam, but do not want to have to pour footings. So 1. are 2x12's enough or do I need a special beam, and 2. will the slab my house is on support that weight without footers?
Thank you in advance.
mdtech123 is offline   Reply With Quote
Old 04-26-2011, 09:52 AM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
Your question can not be answered with any degree accuracy on an internet forum, even one that has a SUUUPPPER GENIUS such as myself on it.
An engineer's analysis is a must have on this one.
Andy.
AndyGump is offline   Reply With Quote
Old 04-26-2011, 01:04 PM   #3
Great thanks. Anyone else have similar experience?
Old 04-26-2011, 01:15 PM   #4
AndyGump's Avatar
Rewards Points: 688
Allrighty then, my work here is done.
Andy.
Old 04-27-2011, 11:23 PM   #5
Registered User
Rewards Points: 526
The built-up beam or engineered wood beam is on charts, the slab is only 4" and the point load under the supports may require 6-12" thick by ? wide concrete footing to disperse the load, depending on soil and engineering calculations. We can help you build it, not design it. You will want a paper trail for this for your Homeowners Insurance carrier and when you go to sell it will be in your house records with the County.
Gary
Advice Needed on [UK] Home Repair Bill cookerz Building & Construction 1 01-09-2010 08:53 PM
Double Door Alignment Advice Needed Lovegasoline Building & Construction 6 12-15-2009 01:32 PM
Needed basement advice... gripp2020 HVAC 4 11-28-2009 11:43 PM
Home electrical advice needed jiminy Electrical 11 12-14-2007 03:13 PM
bathroom floor tile job advice needed dbrew Flooring 14 01-23-2007 07:03 PM
