Originally Posted by Bob Mariani
you can buy recessed boxes to do everything you are trying to do. Much easier way to go. But that being put aside. you need to make the floor of the recess sloped to help drain water into the shower area. Then everything inside the recess needs to be completely waterproofed. I use EDPM menbrane for this. no need to use cornerbead Use bullnose tiles to give a clean edge all around the recess.
leave anything you install over the lip up of the lip at least 1/4" to prevent wicking
Thanks for the reply
What Degree of slope is usually used,so the water can run off but not have the Shampoo go for a walk too
We didn't plan on Bullnose tile,I don't even think we can find something to match.
What if we can't find a bullnose tile,should the corner bead be use with some caulking.
The second pocket for baths,does it matter how high up the tub
I didn't understand your last sentence to well,can you explain please about the wicking
8x13
