Has Anyone Here Worked With Crackle Glass Tile? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-04-2013, 12:28 PM   #1
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
I was asked to install some under cabinet lights and some wall switches. The wire is in conduit, so I can pull through switch legs, the boxes are 1900 boxes so all I'd have to do is change out the rings to two-gang and then install the lights.
But the homeowners had just had installed glass backsplash tile. When I told them I'd have to cut the tile to allow for the addition of a switch, they both froze. Then they explained the glass was cracked, by design, by running it through a hot furnace (this from the factory). They said the installers experienced a nightmare cutting it, even with a wet saw. The tile would shatter and shards flew everywhere.
I thought maybe the installers were inexperienced. Why would anyone make tile that is so dangerous to cut?
So I'm wondering if anyone here has worked with this and if so, is it really that bad or could it be the installers that were the problem?
JulieMor is offline   Reply With Quote
Old 09-04-2013, 06:34 PM   #2
Rewards Points: 5,974
I have never heard of such tile. What size are they? I have worked with glass tile but never these. If I was you I might try to get ahold of the installers.
Old 09-05-2013, 02:38 AM   #3
747
registered
747's Avatar
Rewards Points: 534
I know what your talking about. I say walk away. I'm not confident it wouldn't tear out or something during cutting. (stability issue)
747 is offline   Reply With Quote
Old 09-05-2013, 09:34 AM   #4
JulieMor's Avatar
Rewards Points: 518
After I again asked if they would be okay with me cutting the tile (I told them I couldn't be responsible for what happens), they said they are going to put the project on hold.
I did some reading up in between and saw things like using superglue to fill the cracks before cutting and using a thin diamond blade, not the standard tile cutting blade.
I just wonder how many HOs buy this tile without a clue of how hard it is to work with?
Tile backsplash with marble and glass mosaic ponch37300 Tiling, ceramics, marble 13 05-02-2013 08:38 AM
Do you have to seal marble and glass mosaic tile that is in the shower? debbieriddle Tiling, ceramics, marble 12 07-14-2012 10:32 PM
glass tile on Kerdi dtrueman Flooring 4 05-15-2012 09:58 PM
adhesive back glass mosaic tile dzy Kitchen & Bath Remodeling 1 04-29-2011 11:34 AM
removing glass 4x4 tile tilewoes Building & Construction 1 06-10-2008 09:54 PM
