Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-23-2011, 12:19 PM   #1
Has anyone built a hot water pressure washer ?
Hi all, newby here. Has anyone built their own hot water pressure washer ? And do you have a link to the build. Wasn't sure where to post.
Thank you,
Dave
Sin-city-custom is offline   Reply With Quote
Old 02-23-2011, 01:14 PM   #2
A "Handy Husband"
rjniles's Avatar
Just hook up a regular pressure washer to a hot water supply
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 02-23-2011, 01:49 PM   #3
I think there are "suggestions" in the paperwork that this not be done.
Ron
Old 02-23-2011, 03:14 PM   #4
I'm interested in doing it right, diesel burner and all. Had one where I worked before. Just don't have $3000 to buy one.
Old 02-24-2011, 06:45 PM   #5
Household Handyman
Most/almost all pressure washer's sold now will not tolerate water above about 110º. Any higher and the seals will start to deteriorate. Depending on the manufacturer of the pump, you may be able to find a "hot water seal kit" to rebuild your pump. But then, you should have some knowledge of how to rebuild a pressure washer pump.
Old 02-25-2011, 06:32 AM   #6
SinCity,
Heating and controlling high-temperature water sounds like an accident waiting to happen.
You'll need to regulate fuel with metering valves, connected to temp sensors.
Water flow sensors, thermostats, motor control, pump, pressure relief valves, etc,etc.
There's a good reason these things cost $3K.....because they're complicated pieces of equipment
to manufacture, (and the makers have to pay big bucks for liability insurance to protect themselves from inherent burn suits).
If you've used them in the past you know the dangers involved.
Your safest and best bet will be to either find a used one on E-bay or CraigsList,
or save up till you can get a nice new one.
Or like the others have said, retro-fit a cold-water pressure washer with high temp seals.
Good Luck
Do It Right is offline   Reply With Quote
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 10:03 PM
what is the thing called that stores water under pressure for low water pressure? oregongirl23 Plumbing 18 08-08-2010 03:09 PM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 07:04 AM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 10:50 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
