Has Anyone Attached A Homemade Canvas - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-18-2010, 09:10 PM   #1
has anyone attached a homemade canvas
awning to a mobile home? what kind of tracking or hooks or? you see, i don't even know where to start with this. is there something i can purchase to attach it. i need the awning over the deck that was put on to keep the sun off. with the reflection from the mobile home, its way too hot to even enjoy sitting on the deck. i can't really afford to have a professional come in and put one in so looking for ideas here. thanks
brenda o is offline   Reply With Quote
Old 03-18-2010, 09:29 PM   #2
I used to have a RV with a retractable awning, but I never had to change it! And I'm having trouble recalling how it attached!
I searched and did find this page that may assist you!
http://www.ehow.com/way_5558086_do-i...placement.html
RV awnings are quite expensive and there may be less expensive options available!
This one may be better! http://www.ehow.com/how_5616078_repl...rv-awning.html
Old 03-21-2010, 06:35 AM   #3
thanks for the links. Good resources. I'm still looking for ideas on how to attach the awning itself to the mobile home ie can i use a wooden board as a base, what screws, tools do i need. Then use hooks maybe or is there a track of some sort to get. And how do I keep it taut when its out rather than tying like a tarp, hmmm
Old 03-21-2010, 07:09 AM   #4
attaching to the wall or roof line of a mobile home can be tricky even for the pros. Can the wall handle the added load? A big can of worms..how to flash ledger board to make it 100% water tight (to avoid interior damage). Wind loads... how good are the tie-downs? Do you really want a big sail attached to your home?
All things are possible...BUT:
If the goal is shade:
consider something free standing... Big tent..unbrellas....pergola... quick growing shade trees ( are a very green solution)...
stay safe...
Big Bob is offline   Reply With Quote
Old 03-21-2010, 09:24 AM   #5
As Big Bob mentioned, its tricky to mount something to a RV!
They are usually made with wooden frame and the awning would have to be anchored to this framing. Just fastening it to the sheeting would result in it blowing off and probably taking the sheeting with it!
perhaps you could look at some RV's in a park or sales yard and see how others have done this!
Its testing my memory, but I believe that a special channel is screwed to the frame and then the awning which has a bead sown into to it, is slid into and along the channel.
Of course, there must be different methods of attaching these, I'm sure!
Old 03-21-2010, 10:38 AM   #6
ty but its not to an rv, its to my mobile home
i built a deck last year and want to add an awning of some sort, money tight and the sun is coming
Old 03-21-2010, 10:42 AM   #7
guess i should have read
the post on the "sail" first LOL ok, thanks, i don't want to mess with leaks or siding tear downs. grrr...Maybe i'll opt for an umbrella set or something. but if it could be done........
Old 03-21-2010, 12:16 PM   #8
Put 2 posts near the mobile home, 2 atthe far side of the deck
That way you can attach something & it will not stress the mobile home
Where to buy a canvas drain cleaning bladder??? vsheetz Plumbing 0 01-17-2010 03:05 PM
Proper venting of new roof on attached garage jlatulippe Roofing/Siding 1 11-26-2009 03:24 PM
Attached Pergola stubits Building & Construction 5 08-01-2009 01:07 PM
Building an attached garage BowDown Building & Construction 1 05-20-2009 02:21 PM
Building Attached Carport MikeVila Building & Construction 4 01-12-2009 04:23 PM
