Hardware For Porch Screen Door - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-28-2012, 08:52 PM   #1
Rewards Points: 492
Hardware for Porch Screen Door
The issue I am wondering about has to do with the hardware for my screen door.
When I bought the door, I picked up this piece.
It looks like a good fit in the picture, but the door latch, as I positioned it, does not close unless I remove some of the molding.
I practiced creating the space with a piece of scrap and I my router. I can do it better than this, but this is the general idea.
Curious if this is the type of hardware you would use for a porch door.
I did find a picture of the exact door that I have.
Does anyone know what the piece on the bottom left is? Is that a lock?
As always, thanks for taking a look.
joetab24 is offline   Reply With Quote
Old 02-28-2012, 09:11 PM   #2
jschaben
Rewards Points: 502
I think this is what you are referring to:
http://www.amazon.com/Screen-Spring-.../dp/B003ZWEGGE
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 02-29-2012, 04:56 PM   #3
Rewards Points: 492
deleted post....answered my own question!!
Old 02-29-2012, 05:07 PM   #4
jschaben
Rewards Points: 502
Originally Posted by joetab24 View Post
Is this the only piece I need to buy?
http://www.amazon.com/Battalion-1RBW.../dp/B001H4SKPA
Or do I have to purchase both? (see frequently purchased together) Looks like I will need both.
thanks for your help
Hi Joe - I don't think you need both. They are both just spring loaded overcenter latches. They are not locks though. I dunno about Amazons marketing programs. I think they are supposed to present complimentary items to what you are looking at but in this case they seemed to present duplicate items... both those do the same job.
John Schaben
Old 02-29-2012, 06:03 PM   #5
Rewards Points: 492
thanks, John, I appreciate the help.
One more thing. Since I won't be using the door handle pictured above, so that I can avoid having to notch the molding, any chance there is a handle/knob available that will cover up these holes. Not sure filling them will look good.
Old 02-29-2012, 07:46 PM   #6
Tom Struble's Avatar
Rewards Points: 2,002
you can still use the handle set
Tom Struble is offline   Reply With Quote
Old 02-29-2012, 07:52 PM   #7
Rewards Points: 492
Hey tom,
On the inside, the handle is not clearing the molding. I installed the door handle early on in the project, a mistake I am paying for now. What would you do? Mortise the molding a bit?
Old 02-29-2012, 08:21 PM   #8
yea
Old 02-29-2012, 09:25 PM   #9
Rewards Points: 292
Referring to the first picture you posted with the parts I think the silver piece in the top of the picture is supposed to mount on the surface of the door frame and the handle part then would need to be re onunted further back so that it would latch with that part. The sets I use always come with a spring loaded thing. It takes precise measuring to get the two parts to latch together without sticking or missing. ther should be room to fine tune adjust both parts.
Jim F is offline   Reply With Quote
Old 02-29-2012, 09:39 PM   #10
Hey tom,
recessing the catch would actually be a nice touch,keep things from getting hooked on it
don't be so hard on yourself, looks like your doing fine work
Old 03-02-2012, 10:26 AM   #11
Rewards Points: 492
pleased with the cut, my first time using the router on a project. But I scuffed the surface! Didn't even notice it happening.
I will also be installing the outside latch I discussed above.
Old 03-02-2012, 10:35 AM   #12
Rewards Points: 14,294
That flipper latch on the outside ff the door needs to go.
Reason being those vinyl doors are really flimsy in the first place and everytime the door is opened and closed it's going to try and twist the door.
I always install a turn buckle on them because they start to sag within a year of installing them.
Old 03-02-2012, 10:37 AM   #13
i agree with joe,little more notching then set the catch that came with the handle
Old 03-02-2012, 11:07 AM   #14
Rewards Points: 492
thanks guys,
so, just to be sure, you guys recommend that I do not use the front catch that I was originally asking about.
Regarding the scratches, I think I found a slight dimple on the router plate that is causing the problems.
My first time using the router on a project, so I was pleased, and then I saw the scratches!!
This is Azek, hopefully I can get rid of them.
Screen door...Where to get it? eric s General DIY Discussions 6 04-13-2016 07:03 AM
Stanley Pocket door hardware install P14ZZ4 Carpentry 15 11-03-2010 10:06 AM
Pella Storm Door Hardware Crosseyed08 Building & Construction 0 04-23-2010 07:17 PM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
