Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-07-2005, 07:42 PM   #1
Hardie Board Vs.....?
Can any one explain the pros and cons of hardie board construction vs. block contruction?
I have always owned a block house, and am preparing to have a new home built.
Some builders I have briefly spoke with suggested using "hardie board" as a cost effective alternative to block construction. Is it siding?
Any input would be appreciated.
Thanks.
tattood is offline   Reply With Quote
Old 08-10-2005, 09:21 PM   #2
Its siding. Better than wood. goes up about the same, but guaranteed for like 50 years. Hardie is actually the mfg name. Jameshardie.com will tell you about their products.
Personally, I wanted my current home in a big neighborhood to be brick, but gave the nod when I learned it was hardie planks instead of traditional wood planks.
You can get it prepainted, at minimum it comes primed. Supposedly, paint lasts much longer on it, too.
Neil_K is offline   Reply With Quote
Old 08-10-2005, 10:26 PM   #3
Contractor
Stick with block. Hardie is over frame. The 2 construction practices are nowhere near the same. MHO
Teetorbilt is offline   Reply With Quote
Installing backerboard - replace particle board? salvop Flooring 10 04-29-2011 11:32 PM
Hardie Board Siding and Wind gordo409 Building & Construction 2 07-10-2007 07:00 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 10:33 PM
particle board / hardibacker fish3211 Flooring 4 08-10-2005 09:32 PM
