Hardibacker Over Plaster Wall - Help! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-13-2014, 01:45 PM   #1
Hardibacker over plaster wall - Help!
Updating 1958 bath. Tile and it's concrete/metal lath base removed. Rock lath in great shape. Questions are...
Can I attach Hardibacker/thinset over the plaster?
The HB screws are 1 1/4" long. The wall thickness, about an 1", plus the 1/4" HB, will mean the screws are not going into the studs, only the plaster. This OK?
Thanks....Bart
Sharps 74 is offline   Reply With Quote
Old 02-13-2014, 02:24 PM   #2
Rewards Points: 14,026
I'd use this instead.
http://www.schluter.com/6_1_ditra.aspx
Tile board is not water proof and may effect the old plaster.
Old 02-13-2014, 04:39 PM   #3
Rewards Points: 79
Is this for the walls or floor?
Ditra is a great product for floors, but I believe Kerdi is meant for showers / tubs. And it is supposed to be installed over sheetrock IIRC.
spta97 is offline   Reply With Quote
Old 02-13-2014, 05:42 PM   #4
For the walls.......
Old 02-13-2014, 06:56 PM   #5
Rewards Points: 5,994
Kerdi is a water PROOF material that is commonly used in showers over most any backer board. There are some good install videos on you tube. But to make the shower water proof and worry free you need the whole kit. This includes corners and banding. Ditra the waffle looking one is usually used for floors.
ToolSeeker is online now   Reply With Quote
Old 02-13-2014, 09:19 PM   #6
Professional
TotalHomeworx's Avatar
Kerdi can be a PITA and I avoid it. There are lots of easier ways to do it. Do some research before you commit.
www.totalhomeworx.ca
TotalHomeworx is offline   Reply With Quote
Old 02-13-2014, 10:09 PM   #7
Opp's, my bad I hit the wrong web site ToolSeeker.
ToolSeeker (02-14-2014)
Old 02-14-2014, 03:28 PM   #8
Thanks for the ideas; however, I decided to take all down to the studs. So far, not too dusty and not that difficult except for the metal lath areas which are sort of a pain.
Bart
Old 02-14-2014, 04:40 PM   #9
I think in the end you will be glad you did it this way.
Old 02-14-2014, 06:42 PM   #10
Going to have check the studs with a string pulled tight to see how flat they are and shim them out to make up for thickness of the old wall covering.
Closing off Doorway in Plaster Wall bobdod04 Drywall & Plaster 5 08-10-2013 05:25 PM
Taking Down a Plaster Wall. shane2 Remodeling 5 02-16-2012 10:37 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
