Hardi Siding As Backerboard - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-18-2010, 07:57 PM   #1
Rewards Points: 14
Hardi siding as backerboard
I have a bunch of leftover Hardipanel 4 x 8 siding scraps that I am thinking of using as backerboard for some interior tiling jobs. Is there any reason not to do this? I assume that the material is essentially the same, but maybe not? I asked the same question of the support folks at Hardi and I got a very generic reply that said "don't do that", but when I asked why not, they would not give me any explanation. Is there a good reason or are they just trying to sell more product. Any recommendations out there?
wadswob is offline   Reply With Quote
Old 11-18-2010, 09:04 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
its not the same,moisture will swell and soften the siding,don't use it for tile backing
Tom Struble is offline   Reply With Quote
Old 11-18-2010, 09:14 PM   #3
Rewards Points: 14
Thanks for the response. That's a little disconcerting that it is designed as siding but can't handle moisture. What am I missing?
Old 11-18-2010, 09:26 PM   #4
try it for yourself,take some and let it get wet on the back you will see how soft and easy to bend it is
the siding is designed to be used in a vertical position allowing it to shed water,2 different products for 2 different uses
Old 11-19-2010, 10:51 AM   #5
Rewards Points: 14
Makes sense. Thanks.
Hardi board plank siding over T1-11 bluefitness Building & Construction 3 12-19-2008 07:55 AM
MW Vinyl windows w/ JChannel + Hardi Board Siding - Proper Flashing? jboeckler Building & Construction 1 09-20-2008 02:55 PM
What do YOU think of this HARDI siding deal?? justdon Remodeling 3 09-16-2007 11:54 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
