Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-17-2007, 06:03 PM   #1
zel
Send a message via AIM to zel
Hard to change position/size of windows?
We would like to change the windows in our bedroom. We would like them to be centered on the wall, wider overall, and the bottom to be higher on the wall, so we can put a bed and nightstands on the wall without blocking the windows. I can provide measurements for the wall, the windows that are there now and generally what size we want, if that will help. I'm wondering how involved this will be?
(the outside is AL siding, we have some extra, never used, of this in storage. We will be residing the house in a few years, so not too concerned with the outside siding not matching perfectly.)
Any thoughts/comments appreciated.
zel is offline   Reply With Quote
Old 04-17-2007, 06:36 PM   #2
Changing the sill height is the easiest. It doesn't involve any structural framing changes. Changing the top height of the window or moving it left or right is much more involved, because you have to change the header that supports the wall above the window opening.
Nate
NateHanson is offline   Reply With Quote
Old 04-17-2007, 06:39 PM   #3
zel
Thanks for the reply. How do you support the wall while removing and installing a new header? Also, would you build one header across the top of all the windows, and frame in the rough openings under it? Or would you build a header for each window? Thanks again. Anywhere to read up on this?
Old 04-17-2007, 07:48 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You would build a temporary framed wall to support the overhead ceiling joists and rafters. Here is a picture where this was done. We had to rebuild the front wall and the corner as well.
If you look at the picture closely, you will see the temp. wall approximitaly 2'-0" inward - from the exterior wall that we ripped out and were reframing. This temp. wall supports the weight of the roofline and the rafters above. Prior to doing something like this, you would need to confirm the exact location of your ceiling framing members and the direction that they run in.
You would also need to confirm that there are no additional loads planing down or connected to the wall to be worked on.
One header would be the way to go. This header would need to be capable to support the weight load that the wall is carrying. You can try to get this calculated by the lumber company that you purchase the materials from - rather than simply 'guessing'. Also, check with your local building dept. Remember too, that such a job will require a building permit.
Here is a link:
http://www.extremehowto.com/xh/artic...ticle_id=60193
- Build Well -
Old 04-17-2007, 08:01 PM   #5
Zel,
Please realize that such a project rates high in terms of 'difficulty' and CAUTION for a DIYer.
You should get some additional local professional advice or even onsite help - in undertaking something like this.
Good Luck
- Build Well -
Old 04-17-2007, 08:40 PM   #6
zel
Thanks for the info! I will definately get some help with this one. Another point I should mention is that the vaulted ceiling is basically a false vaulted ceiling. I dont know a good way to explain it, except that when you go in the attic, you can climb on top of the vaulted ceiling joists and above your head are the real roof rafters. I'm definately not sure how I would support the real roof rafters. I would think supporting the "fake" ceiling wouldnt be too difficult though.
Also, I took some measurements. The windows are 39" each and there is 2. One is centered directly under the peak (false), the other is to the left when in the room looking out. Would there be an easy way to add another of the same size window to the right, to balance them out? I realise this would mean either replacing or somehow extending the header. Is this possible?
Thanks again, pictues mean 1000 words!
Old 04-21-2007, 11:06 AM   #7
zel
It looks like we are going to go ahead with the plan of changing the windows to something that fits the wall and it centgered under the peak, even if it means it will take longer to sleep in the new bedroom.
Heres what it looks like now. Between the blue tape on the window is the center of the peak.
Old 04-21-2007, 04:39 PM   #8
Hi Zel,
Yes, I agree by your picuture, that room needs a 'bigger group of windows' that is also 'centered'.
It will make a huge difference. Even something as simple as a triple mulled window can add alot of light and style to a room. Example:
- Build Well -
Old 04-21-2007, 04:48 PM   #9
zel
That is darn close to what we are looking for. I did alot of measuring and writing on the walls today. What we have in mind is:
-roughly 6' of widow in the center of the room, a 2' fixed center section flanked by a 2' double hung on the sides with a fixed arch window above the center section.
-roughly (still deciding this) 1' from the side walls, and on both sides, an 18" full casement with the cranks to open up. These would in theory, be right above the nightstands.
The bottom of all these windows would be at 3' (still not set in stone). Currently the bottom of the windows pictured is approx. 2'. I will be drawing it up on graph paper to get a visual, if it isnt too big, I will scan it and post it.
BTW- what did you use to trim that window. I've never seen such smooth contemporary trim like that, but it looks great!
Old 04-21-2007, 05:06 PM   #10
You're going to laugh about this. What you see was originally fluted casing on the sides and tops with rosettes.
Home Owner didn't like it. ...(everyone has their own tastes).
She wanted something different. Unfortunately the trim work was all done and tied tightly into the new window frame and jambs.
Sooo......I cut and installed 1/4" sanded plywood 'squares' over the rosettes. Then filled in the 'flutes' with joint compound and ready patch. Primed and painted. What you see is what she got. She liked it.
Here's a picture of a stained glass window we made for her. She ordered the stained glass and we built a window frame for it (fabricated it into an interior window). The frame mimics the design of the existing trimwork in her home:
Side facing stairwell:
- Build Well -
Old 04-21-2007, 05:27 PM   #11
zel
lol, I cant believe you had to fill in all the "flutes" on that trim. That must have been a pain. I like the smooth lines it has now. I'd just hate to have to change the door casings in the bedroom to match though. My brother just put them up a couple weeks ago. He probably wouldnt be too happy if, I pulled them down. Is there any chance that compound will crack with temperature changes?
Old 04-21-2007, 05:46 PM   #12
No, It is primed over and sealed along with the wood. At that point, it is essentially a 'wood filler/putty'
- Build Well -
Old 04-24-2007, 10:16 PM   #13
zel
Ok, heres what I found when I opened the wall.
http://www.members.aol.com/zelone/demo.jpg
I am planning on an arch over the top plates and 2 double casements below the arch. They will start approximately where the drywall is cut on the sides.
I am wondering if I can leave a large section of the 2 x 12 header that is above the current windows in place for extra support, add some studs in place of the window, and go to a smaller (possibly 2 x 6) header for the casement windows on either side of it?
The only reason I would like to do this would be to allow me to use a window only slightly shorter then what is there now, but to raise it up at least another 6" off the floor. I didnt expect to see such a huge header above that window.
I havent had anyone else over to see this yet, just looking for opinions, based on the picture. I am assuming the studs on top of the header go all the way up to the roof rafters.
I know this might be hard to open, but it was the plan I drew up before opening the wall completely and will have to be modified based on the wall structure. http://members.aol.com/zelone/plan.tif
Old 04-25-2007, 06:38 PM   #14
zel
Any suggestions here? I'm also wondering how big the header above the arch has to be. The Arch is 6' wide and about 15" at its tallest point. I want to install it so that the bottom of the arch site on the top of the top plates seen in the picture.
Old 05-08-2007, 08:01 AM   #15
zel
Project is moving right along...siding is off, foam sheathing is off. I prebuilt the framing for the windows, and one side of the framing is installed.
terrible windows mt232 General Discussion 10 12-28-2008 06:37 AM
Replacing "Aluminum Flared" Windows? bahaisamurai Building & Construction 6 06-07-2007 11:23 AM
How to measure windows for new construction? pastrami Remodeling 1 04-26-2007 08:36 PM
new windows juliejules4 HVAC 12 12-06-2006 02:37 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
