Hanging Punching Bag In Garage - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-19-2009, 07:51 PM   #1
Hanging punching bag in garage
I am trying to hang my punching bag from the ceiling in my garage. It's a water bag that weighs 120lb. Here is a picture of it hanging from a plant hook:
http://picasaweb.google.com/lh/photo...eat=directlink
Here is the area directly above where it is hanging now:
http://picasaweb.google.com/maiku.pi...95939085439890
What is the best way for me to hang it?
I was thinking I could use this:
http://store.titleboxing.com/heavy-d...am-hanger.html
In combination with:
http://store.titleboxing.com/hbs.html
And these:
http://store.titleboxing.com/shook.html
I guess to do that I need to cut a hole in the ceiling to put the hanger in, then put an S-hook/Spring/Spring Hook/Bag. Do I need to do anything to cover up the hole in the ceiling?
Other hanging accessories:
http://store.titleboxing.com/heavy-b...cessories.html
More pictures of the area:
http://picasaweb.google.com/maiku.pi...-ntq_82oyzuQE#
I have no idea what I'm doing when it comes to these things and any advice would be much appreciated!
Isocene is offline   Reply With Quote
Old 05-19-2009, 09:49 PM   #2
Rewards Points: 5,336
You seem to have the correct parts but what beam are you haning this from? How wide? How long? 2x? and what's the span between supports?
Ron
Old 05-20-2009, 06:54 PM   #3
Rewards Points: 2,638
I hung a bag on the second floor of my house once. Similar to what you have there. A good hit would shake the house. I went into the attic and screwed a 1 inch piece of plywood ( I believe it was about 2 ft square ) into the joists to tie the area together and keep the ceiling drywall from cracking. In retrospect. I would suggest as big a piece as practical, and PL premium adhesive and screws. Sorry, I'm not positive about the mounting, but I think I drilled a hole through a joist and the plywood, and held it with a nut from above. No springs on mine.
Mine held up very well, but don't underestimate the beating your ceiling will take.
SPS-1 is offline   Reply With Quote
Old 05-21-2009, 08:20 AM   #4
Registered User
Termite's Avatar
Any holes you make in the garage ceiling should be patched up. The garage ceiling is an effective and required fire membrane to isolate the garage from the remainder of the structure.
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
Hanging shelf (mini "loft") from finished garage ceiling bdr Carpentry 6 11-30-2008 10:31 PM
Garage Door Install marly General DIY Discussions 2 11-17-2008 02:51 PM
Help hanging heavy punching bag from ceiling chrisski1991 Building & Construction 5 03-15-2007 07:46 PM
