Hanging Lincrusta Embossed Wallpaper On My Ceiling - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-30-2015, 10:41 AM   #1
Rewards Points: 35
hanging Lincrusta embossed wallpaper on my ceiling
I have ceilings that are painted a flat or eggshell. Before I hang the Lincrusta wallpaper, can I just sand the ceiling? Or is using lining paper / wallpaper liner better for adhesion? If you don't know, Lincrusta is pretty thick (1/16 to 1/8 inch thick) and heavy.
skiposwald is offline   Reply With Quote
Old 08-31-2015, 04:55 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,122
I have never had and issue with wallpaper sticking to eggshell walls before. Is there some sort of counter indication from the wallpaper manufacturer?
Old 08-31-2015, 02:01 PM   #3
Rewards Points: 35
The manufacturer recommends lining paper, but I don't really see how it helps in my situation yet. Lincrusta is closer to vinyl than paper and, as I said, quite thick.
Old 08-31-2015, 04:47 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 312
I would follow the instructions which most likely say to prime with a wall covering primer as well as lining.
Old 09-05-2015, 04:11 AM   #5
I would suggest sanding down the ceiling with a mirka deros or something similar to give a good key, seal the whole area with a thinned pva mix then follow instructions on how to apply the lincrusta. I presume you are going to use the required lincrusta glue?
joe.elwick.9 is offline   Reply With Quote
Tags
adhesive , lincrusta , lining , sanding , wallpaper
Hanging 70 lb heavybag (punching bag) from ceiling joists in basement. tgm1024 Building & Construction 13 06-06-2015 06:25 AM
How can I install hanging lights thru a suspended ceiling? helenschreiber Electrical 11 07-23-2014 03:50 PM
Live wire hanging from basement ceiling yummy mummy Electrical 30 12-04-2007 10:43 AM
Help hanging heavy punching bag from ceiling chrisski1991 Building & Construction 5 03-15-2007 07:46 PM
Hanging a Wallpaper Border Nathan Painting 10 06-17-2005 01:19 PM
