Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-28-2007, 06:56 PM   #1
Hanging a Heavy Mirror
I’m hoping someone can help me with a question about hanging a large heavy framed mirror. I have a large 2-story high entry foyer and my wife has fallen in love with a mirror she wants hung on the wall. My concern is that the frame is “cast resin” (not wood) and the mirror weighs over 100 lbs. The mirror in question can be viewed at the link below. It comes with 2 D-rings screwed into the back of the frame (one on each side), which don’t seem adequate to me for holding the weight of the mirror in a hanging mount. The mirror is manufactured and sold as a “floor mirror” and it’s my assertion that these D-rings are only to help secure it to the wall to prevent tipping, while the weight of the mirror is supported by resting on the floor – not being hung on a wall.
Any ideas as to a safe/secure way of hanging such a large & heavy mirror that you are aware of?
http://www.hookerfurniture.com/index...oor-mirror.cfm
Any input/advice would be most appreciated.
frapha1 is offline   Reply With Quote
Old 07-28-2007, 09:40 PM   #2
If it were me, I would locate the studs in the wall where you want it hung. Then I would use some heavy duty hooks that screw into the wall. Make sure you hit the studs and the scew hooks go in a ways. If you install one on each side and then use the rings that they mirror has to hang from. If you think the rings on the mirror won't hold. You will have to add some eye hooks to the back of the mirror. Please be careful. Large mirrors like this are meant to be on the floor for a reason. However, I'm sure people have things hanging all over that weigh more than 100lbs. Good luck.
cibula11 is offline   Reply With Quote
Old 07-28-2007, 10:32 PM   #3
Definitely would use the studs to secure any mounting. However, part of my uncertainty is because the entire frame is made of "cast resin" -- not a wood product, so I'm not sure how it would accept screws in the back. I had considered using a cleat hanging system, but again, am a little uncertain about how well anything can be attached to the back of the resin frame. Hoping someone has some insight about the resin frame issue.
Old 07-29-2007, 10:04 AM   #4
Eibwen
I agree those hooks dont sound like they would hold the full weight of the mirror.
Might reinforce all or a portion of the mirror back with some 1x lumber along with expoxy and screws to help disperse the weight across more area/fastners.
Or do a decorative shelf for the mirror to sit on and support it.
Sammy is offline   Reply With Quote
Old 07-29-2007, 11:12 AM   #5
Master Electrician
JohnJ0906's Avatar
IMO, this would be the only safe way to do this, if at all. Keep in mind that you are hanging 100# overhead, and it must be done SAFELY, or not at all. If it falls on someone, it will kill or cripple them.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 01-03-2010, 11:15 AM   #6
ok! the corrected and safe way is to install 3/16 TO 1/4 inch plywood to the wall make sure locating studs.wood should be half the size of the mirror. screw complete board firmly to the studs in the wall.use a stud finder,makes it easer.now that your board is secure now use heavy duty type hangers that you can use haevy duty wood screws.hang your mirror with no worries.hope this helped you.
keith d is offline   Reply With Quote
Old 01-03-2010, 12:21 PM   #7
Drill right through the frame, into the studs and screw it to the wall. You can use a trim screw with a small head and fill the hole with a filler and touch up with paint. Or use a regular screw and put a decorative cap over it.
Ron
Running into difficulties installing bathroom mirror (pics of the nightmare incl.!) joeyboy General Discussion 18 08-10-2007 11:04 AM
How to remove these 'pads'? Solvents? Mechanically? (Pads on mirror!) joeyboy General Discussion 11 08-04-2007 07:01 PM
Help hanging heavy punching bag from ceiling chrisski1991 Building & Construction 5 03-15-2007 08:46 PM
Hanging heavy pictures in an old house BlackRichard Carpentry 4 05-07-2006 09:35 PM
mirror frame jdwdwd Carpentry 3 03-31-2005 10:34 PM
