#16 |
Hanging a heavy framed mirror with no hangers
I'm not sure I understand how putting the adhesive on would screw up the silvering. Mirrors (like on closet doors, etc) are often attached with mirror adhesive, and that seems to be o.k. Now, if the cleat or the board were to pull away, I can see how that would be a mess!
#17 | |
Hanging a heavy framed mirror with no hangersQuote:
#18 |
Rick
How thick and wide is the actual frame? If the glass could be drilled (by you or a pro) then screwing the cleats to the top and bottom rails should work shouldn't it?
Rick |
#19 |
Wildie--the mirror was, in essence, free. So if I screw it up, no big deal. Although of course, I'd rather not.
Rick--it's about 2 3/4" wide, and about 1/2" think (it's decorative baseboard trim). The 2 places I called said they would not drill it. Well, one said maybe, but they'd have to see it first. |
#20 |
Rick
Here's a section view of my other suggestion - adding a perimeter frame...
Is this a possibility? |
#21 |
Rick, that's a good idea. I certainly have enough scrap wood to try it.
#22 |
Rick
sheahasu,
You could even route a small profile in the front edge where it would meet the original frame to make it look like it's all part of the original mirror. Good Luck! Rick |
#23 |
look up gunther mirror mastic.
safe for the silvering, holds very well. Buddy of mine... their family runs a glass shop. I've helped them put up many sheets of mirror with this stuff. keep in mind this is permanent. |
| Tags |
hanging, mirror ![]() |
| Display Modes | |
| Hanging really heavy mirror | beech | Building & Construction | 7 | 05-11-2011 11:33 AM |
| Hanging Heavy Sign Post - Into Brick or Mortar? | nikky_hack | Building & Construction | 6 | 11-17-2010 04:04 PM |
| Hanging a Heavy Mirror | frapha1 | General Discussion | 6 | 01-03-2010 12:21 PM |
| Problen with hanging heavy draperies in sheetrock metal studs wall. | Fixitgeorge | Remodeling | 1 | 04-11-2009 02:03 PM |
| Help hanging heavy punching bag from ceiling | chrisski1991 | Building & Construction | 5 | 03-15-2007 08:46 PM |
