Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-02-2008, 03:14 PM   #1
hanging a dart board
i am trying to hang a dart board in my basement. it has a cabinet and board, in my basement there is a thin layer/sheet of a carboard material that inter locks with wach other,it is fairly soft and eaisy to punch through. it seems lieka igh density cardboard or something along those lines, then there are studs and cynderblock. i am not sure how i should go about mounting it cause the dard board is heavy,. i was thinking about putting in some masonry toggle bolts/ahchors and just putting it up that way, any suggestions????
JAVAMAN is offline   Reply With Quote
Old 01-02-2008, 03:25 PM   #2
Building and plumbing
USP45's Avatar
Why do all that, we can paint circles on my wifes butt...
No, better not
seriouse, I would install it using toggle bolts that are long enough to penetrate the cinder blocks.
USP45 is offline   Reply With Quote
Old 01-02-2008, 03:35 PM   #3
yeah ur wife probaly wouldn't like that thanks for the advice.
Old 01-02-2008, 04:38 PM   #4
Master General ReEngineer
Bondo's Avatar
Ayuh,............
Why not move your shooting lane,+ mount it directly to a Stud,..??..??
Old 01-02-2008, 05:06 PM   #5
Hang it on a stud but be sure that there isn't any piping or electrical in nearby stud cavities. I found out the hard way that a dart will penetrate drywall and 3/4" copper pipe.
WMitch6 is offline   Reply With Quote
Old 01-02-2008, 05:50 PM   #6
(the original)
Make a 3' (square, round, octagonal, whatever you prefer) backboard out of 5/8" plywood, cover it with short-nap carpet, fasten it to the studs, fasten the cabinet and board to the backboard. Done deal!
ratherbefishin' is offline   Reply With Quote
Old 01-02-2008, 06:07 PM   #7
Bondo's Avatar
Ayuh,.......... Great Idea..........
You could even cover it with that sticky backed Corkboard,......
That way the Darts will Stick,+ you won't have to pick them up off the Floor......
Old 01-02-2008, 06:42 PM   #8
Landscape contractor
I used old ceiling tiles ( the kind that have the metal grid hangers) and screwed them to a section of wall about 5-6ft wide up to the ceiling and then painted them, hung the dart board and cabinet and now when my buddies come over and have a few and start throwing crazy I don't have to redo anything!
timber is offline   Reply With Quote
Old 01-03-2008, 08:51 AM   #9
I Am Drilling Throught The Cynderblock But It Seems Like It Is Taking Forever. Why Is This I Think I Will Just Switch To Cement Screw/ Anchors
Old 01-03-2008, 09:01 AM   #10
Bondo's Avatar
Ayuh,..... You Are using a Carbide Tipped drill bit,.. Right,..??
Old 01-03-2008, 09:46 AM   #11
No I Am Using A Standard Masonry Bit. Also Is It Possible That The Cinder Block Is Solid With Wigther Mortar Or A Solid Cinder Block? And Also How Thick Is A Cinder Block
Old 01-03-2008, 10:33 AM   #12
USP45's Avatar
Could well be that its been filled with cement. Try some "Tapcons" or use the suggestion mentioned above by ratherbefishin'Make a 3' (square, round, octagonal, whatever you prefer) backboard out of 5/8" plywood, cover it with short-nap carpet, fasten it to the studs, fasten the cabinet and board to the backboard. Done deal!
Old 01-03-2008, 04:36 PM   #13
This one could possibly make Sir Charles Barkley's FIVE.
JGarth is offline   Reply With Quote
Old 01-07-2008, 08:52 AM   #14
What Do U Mean About Charles Barkleys Five?
I Used The Tapcon Screws They Worked Great Thanks
Installing backerboard - replace particle board? salvop Flooring 10 04-29-2011 11:32 PM
Blower control board mlmaher HVAC 1 11-24-2007 02:39 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 10:33 PM
