Hanging A Bookshelf On The Wall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-09-2008, 10:08 AM   #1
Hanging a bookshelf on the wall
My wife wants to redecorate. One aspect of the theme she has in mind is to hang a bookshelf on a wall (something she saw at a local coffee shop). In theory this allows for book storage without taking up floor space. I can make the bookshelf and can hang it, no problem. My concern is how much weight can a typical interior 2X4 wall support. Any body know the answer to this? I would imagine the shelving to be 30-40 lbs, but books get heavy fast and we have a lot. Any help would be appreciated.
Thanks,
Cobb
Cobb is offline   Reply With Quote
Old 12-10-2008, 07:40 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 340
Ayuh,...
I would think that the load carrying ability of your shelfs will be limited by the shelfs You build,+ How you mount them,...
Not the capacity of the Wall...
Old 12-10-2008, 07:52 AM   #3
the Musigician
DangerMouse's Avatar
as long as you mount it to the wall with lots of screws into the studs, i don't see a weight problem. however, you gave no approx. dimensions as to how large a shelf she desires.
DM
Old 12-10-2008, 08:50 AM   #4
Registered User
Termite's Avatar
Don't give a thought to the studs' capacities. There's no way you're going to exceed it by installing bookshelves, even if they're floor to ceiling.
Old 12-10-2008, 08:59 AM   #5
the Musigician
floor to ceiling? then the floor would hold the weight, not the wall.... i'd worry more about the shelves being built strong enough to hold the weight, not the walls.
DM
Old 12-10-2008, 09:10 AM   #6
As for shelf size the unit will probably be 48 - 64" wide as this will be the best fit for the wall studs. The height will be somewhere around 48".
I was just unsure as to the physics of the whole thing. I know the majority of the weight will be dispersed downward but I was worried about the "pull" on the wall.
Thanks for the input!
Hanging dry wall??? gone_fishing Remodeling 10 12-01-2008 04:39 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
