Hand Rail Post - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-02-2007, 09:22 AM   #1
Rewards Points: 150
hand rail post
I have three steps. How high does the post on the bottom of the steps need to be to attach my handrail?
econdave is offline   Reply With Quote
Old 12-02-2007, 09:31 AM   #2
Oldguy
Rehabber's Avatar
The handrail height from the top of each step is usually 36 to 37 inches, however different communities have different code requirements.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-02-2007, 01:29 PM   #3
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
Min. 36" to the top of the handrail mesured from the nose of the step. So your post needs to place for that.
Kingfisher is offline   Reply With Quote
Old 12-02-2007, 05:02 PM   #4
remodeling pro
Note Kingfishers wording, it makes a big difference. The height of the handrail is measured at a plumb line at the front edge of the stair nosing, not just "from the top of the step". Measuring anywhere else along the step will change the height of the rail, usually putting it out of legal range.
troubleseeker is offline   Reply With Quote
wood fence post farrington135 Building & Construction 11 05-17-2011 03:32 PM
Post mounted electrical receptacle NIlRO Electrical 13 04-19-2010 03:20 PM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
