Halogen Light In Cabinet? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-17-2010, 02:23 PM   #1
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 682
Halogen light in Cabinet?
I have installed the cabinets pictured below in my office. I am going to put a light in behind the glass doors.
I purchased a light from Home Depot last night - your basic 120v halogen "puck" light. I wanted LED, but my wife didn't like the color of the light output, so I reluctantly got halogen.
Like this:
I am a little concerned about the heat output of a halogen lamp inside the cabinet. The directions say "not for surface mounting inside kitchen cabinets or china cabinets." Does that mean I can't recess mount the light? (the light mounts recessed or surface).
Above the top of the cabinet is an open area, framed out by 1x4s. Crown moulding will be wrapping around the cabineted area, attached to the ceiling and 1x4s.
hyunelan2 is offline   Reply With Quote
Old 08-17-2010, 03:41 PM   #2
joed's Avatar
Rewards Points: 11,548
I means you can't surface mount it. The heat is probably too high and possible burn issue with wood above it. If it is recessed then it shoul be open air above it.
Old 08-18-2010, 12:05 AM   #3
firehawkmph's Avatar
Rewards Points: 1,800
Hu,
Tresco makes led pucks called ' pockit'. They have to different color outputs. One is whitish, the other a softer, more yellowish. They don't get hot, use 1 watt per puck. They can be surface mounted or recessed with a 2 1/8" hole. They do require a separate transformer, which can handle up to six lights. Here's a link:
http://www.rockler.com/product.cfm?page=22239
Mike Hawkins
firehawkmph is offline   Reply With Quote
Extend a circuit/draw power from light Ontario Electrical 3 03-23-2010 07:41 PM
Condensation in overhead light JB Toyz Electrical 0 12-06-2009 03:40 PM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 07:39 AM
Under cabinet Light Suggestions jamiedolan Electrical 7 04-01-2009 12:59 PM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 09:28 AM
