Gyprocing A Basement Ceiling - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-09-2009, 12:40 PM   #1
Gyprocing a basement ceiling
When I gyproc my basement ceiling do I have to put slats (1x3's or 4's) up under the joists or can I put the gyproc directly onto the joists. I have no wires, pipes etc hanging below the joists so I think directly onto the joists would work - any wisdom would be appreciated.
BrianD is offline   Reply With Quote
Old 04-09-2009, 12:58 PM   #2
47_47's Avatar
Rewards Points: 44
There are several reasons for the strapping. Most times the bottom of the joists are not even, and you can shim the strapping to get your ceiling flat. Another is it will give you a wider area for the joints between the sheets (you're not splitting a 2x in half).
If the bottom of your joists are even and 16" OC, I'd screw and glue the sheets directly. Make sure you use the correct thickness and type for your application.
47_47 is offline   Reply With Quote
Old 04-09-2009, 05:11 PM   #3
We just finished our basement not too long ago and screwed directly to the joists. It's a 52 year old house with 2x8 joists and it turned out great. In new houses everything is screwed directly to the joists but alot of joists used in the better housing now are TGI joists. Drywall is screwed directly to all the other joists, no different in the basement. WHen I say 'better housing' I mean custom houses.
joel v. is offline   Reply With Quote
Old 04-10-2009, 01:54 PM   #4
Drywall contractor
Rewards Points: 1,070
No need for strapping. As stated above, glue and nail/screw.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Drywalling my basement ceiling luweee Remodeling 5 03-24-2009 07:58 PM
Five inch ductwork in basement ceiling - how to end the run? drnormie HVAC 5 11-25-2008 10:21 AM
Work lights in basement with drop ceiling fw2007 Electrical 2 10-20-2007 10:39 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
