Gutter Fitting? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-02-2013, 09:01 PM   #1
Rewards Points: 105
Gutter fitting?
A friend of mine has original gutters run through the soffits as well as gutters on the fascia board. He says the previous homeowner put them up because water poured over the fascia. The downspout has a hole cut out of it and flex pvc spout connecting that always falls out and looks sloppy. My question is where can I find a tee solve this problem?
r1racer is offline   Reply With Quote
Old 08-02-2013, 10:49 PM   #2
A Little Of Everything
Rewards Points: 1,364
Wow. This has about 10 layers of bizarre written all over it.
The proper pieces to replace that flex-tube debacle can be found at any lumberyard or box store. You'll have to do a little cutting, and it won't come anywhere near 100% right, but it'll be better than what's currently there.
DrHicks is offline   Reply With Quote
The Following 2 Users Say Thank You to DrHicks For This Useful Post:
gregzoll (08-03-2013), user1007 (08-03-2013)
Old 08-02-2013, 10:57 PM   #3
Rewards Points: 282
A Y is what you need there. I don't know if any of the hardware chains carry them. You may have to order online.
Jim F is offline   Reply With Quote
Old 08-02-2013, 11:20 PM   #4
Rewards Points: 105
Not sure how he could use the Y without using another elbow which would look kind of ridiculous.
Is there a place to buy those tees or are they custom made?
Old 08-03-2013, 01:11 AM   #5
Rewards Points: 6,652
You can make your own if you wish, by taking the time to do it, and using a Dremel multi-tool for cutting, for the example in post #3.
Old 08-03-2013, 05:54 AM   #6
Too Short? Cut it Again!
This concept is rube goldberg goofy. If those gutters buried ever clog up or leak, a y connection is the least of your problems. Too, too weird. And just looking at that downspout I am guessing the outer gutters have not been cleaned out in awhile?
I take it this is a flat roof though? Seems to me the major issues are with the roof and gutters will not fix it? Call a roofing contractor to fix this. I do not think it is DIY.
And for the record I have never seen a gutter system buried like this.
Old 08-03-2013, 06:46 AM   #7
It's called a yankee gutter, or box gutter and was quite popular up north for a while.
roger_ is offline   Reply With Quote
Old 08-03-2013, 08:28 AM   #8
Rewards Points: 105
It's not the box system, it's called an Integral System. Supposedly the system worked until a new roof was put on. Although this system doesn't seem to be the most practical, the house was built beautifully by a commercial building contractor. It's the hack jobs that came after that usually f things up. The entire rolled roof was done poorly. There are places on that roof where I can stick my hands in between the seems.
http://www.usraingutter.com/differen...r-systems.html
Gutter fitting?-gutter2.jpg   Gutter fitting?-gutter3.jpg   Gutter fitting?-gutter-4.jpg   Gutter fitting?-gutter-5.jpg   Gutter fitting?-gutter-6.jpg
Old 08-03-2013, 08:34 AM   #9
Rewards Points: 13,750
That style roofing is the lowest of the low grade of roofing!!!
Someone was looking to cheap out on that one.
No way would I have even considered buying a home with that type roofing on it until it was replaced.
Even if it was installed perfect you only get about 10 years out of it if your lucky.
Old 08-03-2013, 08:47 AM   #10
Rewards Points: 105
Because of the slope it has to be rolled...and yes it is **** quality. The roof is so large though rolled is the best value. It's 35k minimum for a rolled roof and with a new gutter system and higher quality material we are talking big bucks. Like I said, people that owned the house before hired hacks.
Old 08-03-2013, 08:49 AM   #11
And you are still asking us whether we can find you a y to fix the gutters?And whether it will fix this?
Nice roofing can be expensive. Without it, and a nice hat on a home, nothing else matters much when you think about it.
Old 08-03-2013, 08:56 AM   #12
Rewards Points: 105
For now, yup.
Old 08-05-2013, 08:52 PM   #13
Rewards Points: 282
It looks like they cheaped out on the overlap with the rolled roofing. The sooner you can have that replaced the better and plan on having them bypass that internal rain collecting system while they are at it.
How to screw in a gutter mj12 Roofing/Siding 2 06-28-2013 09:16 PM
Attach gutter to "crown molding" or remove? rxb Roofing/Siding 6 11-01-2012 09:01 AM
Gutter installation questions Homerepairguy Roofing/Siding 7 03-15-2012 10:22 AM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
