Gutter Downspout Option - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old Yesterday, 05:02 PM   #1
Rewards Points: 77
I am wanting to replace some of my gutter downspouts that are rusted and damaged. Where all the pieces connect water leaks out of those areas. Where the the down spout starts to curve at the bottom near the opening it comes out of the back side where two pieces connect causing the water to run on my foundation which has now started causing damage in that area.
What is the best type of material to use for a downspout? If it is the aluminum what was can I seal between connecting pieces to prevent leaking? Is there a particular piece that should go on the inside and one on the outside...like when connecting does it matter if the upper or lower piece is on the inside or out? Any suggestions would be great!!!
Zach McKain
mckain87 is online now   Reply With Quote
Old Yesterday, 06:22 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,286
No need to seal the downspout sections. The are lapped joints and the water passes over one section inside of the next.
Old Yesterday, 09:59 PM   #3
Rewards Points: 22
bottom piece always over the upper so like windows said the water will always just transition. no need to seal.
you can do aluminum or even crush proof PVC these days.
barnabas131 is offline   Reply With Quote
Old Today, 12:11 AM   #4
Rewards Points: 1,778
Very likely your down spouts where assembled backwards, easy to do.
Gymschu (Today)
Old Today, 07:17 AM   #5
Rewards Points: 850
Rusting gutter parts should be replaced. Don't go back to galvanized parts. Use heavy duty aluminum parts from roofing store, not homedepot.
carpdad is offline   Reply With Quote
Need help with extending my downspout underground... DIYguy2000 Landscaping & Lawn Care 1 09-11-2014 02:25 PM
Should I add a downspout? scottyv81 Roofing/Siding 5 05-09-2012 08:37 PM
Yankee gutter resurfacing options miamicuse Roofing/Siding 24 01-06-2012 09:20 AM
Downspout, gutter, and gutter guard installation asmith_01 Building & Construction 2 01-13-2011 07:23 AM
HELP Heavy Snow, iced-up gutter, leaky windows Venner Roofing/Siding 8 12-10-2010 09:55 PM
