Guidance On Buying A Compressor - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-10-2012, 09:41 PM   #16
Special User
Rewards Points: 1,230
Originally Posted by Scottg View Post
Now I'm thinking 3g and separate tank for that one task.
Yeah, my thinking exactly. I got my 11g tank from Harbor Freight for $35, and you can often find 20% off coupons in magazines.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-11-2012, 12:01 AM   #17
What ever you buy if you don't use it every day don't store if with air in it open the drain and leave it open. I had a nice Cratsmam 30gal compressor. I drained the tank of water after heavy use. It lasted 30 years, then the tank rusted thru. The air in the tank will make condensation every time the temp changes around the out side of the tank.
Hardway is offline   Reply With Quote
The Following User Says Thank You to Hardway For This Useful Post:
ToolSeeker (12-11-2012)
Old 12-11-2012, 09:47 PM   #18
Registered User
Rewards Points: 5,514
Big difference in noise of oil-less or not...weight a problem, get the twin-tank aluminum from Sears or HF, 20gal. 3.5 or 5hp will run a framing crew of 3... pancake will drive everyone nearby- crazy or deaf.. my 2 cents.
Gary
Old 02-22-2013, 09:24 PM   #19
Guidance on Buying a Compressor
buy a ridgid Tri-stack. 4.9cfm @90psi
you can seperate the compressor for the small trim jobs.
williampierce is offline   Reply With Quote
Old 06-18-2013, 10:44 PM   #20
Rewards Points: 263
Ended up getting the Porter Cable 6 gal on a Father's Day Home Depot sale for $199 with framing nailer and brad nailer. I got a crown stapler separately.
Love this thing. Should have done long ago. Already used it to chicken wire up some enclosed garden structures and attach some shelving.
ONE PROBLEM THAT I'M A BIT ANNOYED WITH.
Apparently, you're supposed to break it in for 15 minutes with the drain valve open. I didn't do that. I've only got a couple of hours on it now, but I'm not sure if it would help to do that at all, since I drained the air out of it after use. So any condensation should have gotten blown out then.
I'm a manual reader. And I did read the manual, but somehow missed this snippet and read about it online.
Scottg is offline   Reply With Quote
buying a nail gun with compressor Dave777 Tools 9 11-27-2011 11:37 PM
Help assembling compressor jfhspike Tools 5 03-27-2011 10:07 AM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
help buying air compressor ugabulldog Tools 2 08-28-2010 11:54 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
