-   -   Guessing alarm code (http://www.diychatroom.com/f2/guessing-alarm-code-178314/)
vect0r 04-28-2013 09:05 PM
Guessing alarm code
We just moved in to a home with a Brinks bhs-4000a alarm system. The previous owner didn't leave any information on the master code. If I take a few guesses at it do I risk locking out the system?
Thanks!
Exjay 04-28-2013 09:28 PM
I assume the alarm is currently not monitored? if it is the company should provide this info to you or try to get in touch with the previous owner. Not too sure on the Brinks panel but we removed a ADT Vista panel from a commercial business that we bought and I installed in my home (had no code) but a few searches online to some alarm forums I was able to ask and come up with the programming manual and I was able to reset it and set my own code. there should be some sort of default/master reset code but some companies lock out their panel if you disconnect svc with them, then your at their mercy. On a side note, it wouldnt hurt to unplug the phone seizure line at the panel before hitting more buttons. You will need a code to silence a audible siren if you accidently hit the "panic" key (or just disco the siren first)
vect0r 04-28-2013 09:41 PM
I've had a hard time finding much material online for this system. The manual says the installer tech sets the first code. I can't find an installer code anywhere online. I'd be testing the codes by trying to turn on the door chime (that way I don't have a siren screaming for 5 mins)
Hardway 04-28-2013 10:11 PM
The odds you hitting the code by hit and miss are almost impossible.
ddawg16 04-28-2013 10:40 PM
Most of the codes are 4 digits.....you only have to try 9999 different combinations.
joed 04-28-2013 10:46 PM
Some installer do not give the home owner the master code. That way you are forced to keep up the contract with them.
user1007 04-29-2013 05:20 AM
Might call a locksmith that works with alarm systems. They should be able to get into it for you and provide you with a master code.
If you need to establish central monitoring anyhow, the new company you choose will be able to get you up and running.
danpik 04-29-2013 06:42 AM
Actually, if you start with 0000 it is 10,000. Should not take too long
Larryh86GT 04-29-2013 07:12 AM
Start with the easy ones: 1234, 1111, 2222, 3333 etc. :whistling2:
md2lgyk 04-29-2013 07:44 AM
Out of curiosity, are you intending to use this system? Will it be monitored? Speaking from personal experience (some of it not so good), you must be sure that everyone living in the house, including all children, clearly understand how the system works, what to do if it goes off, and the pass code, especially if it goes off by accident. Give a wrong or garbled answer when the monitoring company calls and you'll usually get a visit from the police and probably an ambulance as well. Some locales will also fine you for too many false alarms.
We personally no longer have an alarm system in our home. In 20 years of having them, we never once had an alarm that wasn't accidental.
RWolff 04-29-2013 09:33 AM
Brinks bhs-4000a alarm system seems to be made by Honeywell, you might try them. There's a bunch of Brinks bhs-4000a alarm system systems and parts on Ebay, most of what I briefly scanned in the list were under $100
so it doesn't sound like this is some kind of $2000 system, it might actually be cheaper to replace it with one that has all the codes and parts than calling a locksmith out who I'm sure is going to charge more than $100 to drive out, anything less is barely worth the guy's time.
Just get a .38 or a good dog, alarms can be a PITA, and nothing is more fun than accidental alarms in the middle of the night!
TheBobmanNH 04-29-2013 10:46 AM
Quoted for truth. Disconnect the thing and never look at it again, you'll be a much happier person.
ddawg16 04-29-2013 11:08 AM
The only thing an alarm system does is let you know what time you were broke into.
We have talked about it before....
Your best security is a dog. 99% of burglars will find anther house.
Next...don't advertise....they they don't know you have it, they don't want it.
If your really concerned...then look into cameras. They make them now so that they can email you a pic when motion is detected....you can then go on a web page or with your phone and see what is happening....if someone is breaking in...you call the police and give them a blow by blow description of what is going on.
At min...just recording the burglar will usually lead to their arrest.
Exjay 04-29-2013 06:46 PM
If you have a 4 digit house number try that first. Get a yard sign if all else fails and some motion flood lights.
PoleCat 05-01-2013 08:27 AM
Geometric patterns are common too.
