Grill Sealant Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-15-2009, 12:01 PM   #1
Question
I'm making an outdoor grill with a keg and an old cabinet. I cut out a hole in the countertop of the cabinet to fit the keg in. The countertop is wood with fermica.
When I drop the keg into the hole in the countertop I have space around the keg that I want to seal up. Is there some sort of sealant I can use that will hold the keg in place and be able to handle high heat and not melt?
hugg0029 is offline   Reply With Quote
Old 03-15-2009, 12:17 PM   #2
Rewards Points: 158
Can you post a couple pictures? It sounds like a cool idea, but IMHO, even with a high-heat sealant between the keg and the countertop, it still seems like there is a 99.9999999% chance of the rest of the cabinet or countertop catching on fire.
gma2rjc is offline   Reply With Quote
Old 03-15-2009, 03:13 PM   #3
Remodeling Contractor
you will need a two inch space between the keg and the counter for the counter not to burn. Some say a cool idea, but a hot idea may soon show to be the case. if you use this spacing, buy a flue collar from a fireplace supply store to use as this flange to seal the edges.
Old 05-26-2009, 11:26 AM   #4
I have a similar question -
I have a nice drop-in grill that I want to put into a pre-fab countertop (low-cost kind from Lowes that you might use in a kitchen or bathroom).
The idea would be to cut the recommended space and "drop" in the grill into the cut-out. Provided the adequate venting is there, I think this is a good application... however...
I'm concerned about the heat transfer from the metal touching the countertop edge, and also a bit concerned about the heat from the grill coming in contact with the dense particle board that makes up the counter itself.
I was trying to decide if using a fire-proof sealant (such as DAP Fire Stop) would do the trick to ensure that if the surface did get hot, it wouldn't combust. That also helps alleviate any moisture issue from water getting on the exposed wood...
Ideas?
oldsntnick is offline   Reply With Quote
Old 05-26-2009, 01:02 PM   #5
fire stop caulking if to prevent air flow and provide a low flame caulking. It would not hurt but would not help much either. You could pack the edges with mineral wool (steel wool). The loose fibers will stop heat transfer. but the edges of a drop in grill are not much of a concern anyway. Heat rises.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
Another question about roof sealant products darsunt Roofing/Siding 9 10-28-2007 10:24 PM
New service Question Onytay Electrical 1 10-24-2007 06:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
