-   -   Great Stuff Foam Between Walls (http://www.diychatroom.com/f2/great-stuff-foam-between-walls-75392/)
chadwilliam1 07-04-2010 02:59 PM
I have an older home with Rock Lathe and plaster. There are fur strips so I have roughly 3/5 of an inch between my exterior wall and interior wall.
If I bought a bunch of cans of that great stuff foam and sprayed into my walls would that help? I was thinking about drilling a bunch of quarter inch holes and blowing that into the holes. Than patching and painting.
nap 07-04-2010 03:27 PM
is 3/5 actually 3/5 or do you mean 3 to 5 inches?
If the first, that is not enough to do much of anything other than prevent air infiltration,
If the latter, spray foam is a possibility but the little cans aren't cheap and you have to be careful about expanding foam. It can bow out a wall.
You could blow in glass or cellulose insulation or there is a foam (icynene I think) that is made to be installed into a closed wall. via the hole in the wall method.
the problem you have to be concerned with is getting adequate fill. That is where the proper tools would be extremely important and the little can with the little nozzle just isn't going to cut it.
chadwilliam1 07-04-2010 06:37 PM
I opted not to do it. I meant 3/4. I Agree with what you are saying. I would need too many cans and too many holes.
