Granite Tiles - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-08-2009, 12:22 AM   #1
Question
Granite tiles
I need to know if there is a way to remove 12x12 granite tiles from a counter top without breaking them
hazel burney is offline   Reply With Quote
Old 02-08-2009, 12:57 AM   #2
Registered User
Termite's Avatar
Hazel, I moved your post from the introductions subforum as it is not an introduction.
Welcome to DIY chatroom.
The answer depends on how well the tiles are stuck down and with what. If it was done right I doubt you'll have any luck saving the tiles. You might get lucky on a few, but granite tiles are relatively thin and since they're rock they definately will crack.
Why are you taking them up/trying to save them?
Old 02-08-2009, 02:32 PM   #3
Rewards Points: 5,336
And as thekctermite said, "if it was done right". Who did the job? If it was a DIY job, you can probably get quite a few off as they probably didn't do it correctly. Wrong substrate, wrong adhesive/thinset will increase your chances on saving some. If an adhesive was used, you can try using a heat gun to soften it up. Then take a stiff taping knife and slide under the tile to break the connection by gently lifting while still applying heat. With the larger tiles, you'll need something that will reach deeper into the back to get the penetration you need.
If they used thinset made for granite and a cement backer board as a substrate, you'll be lucky to recover 10% of the tile.
Ron
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 12:44 PM
Hardwood surronded by granite tiles coleen66 Flooring 11 03-22-2008 09:08 PM
Installing 24" granite tiles over existing kitchen countertop? pford Carpentry 3 01-25-2008 11:16 PM
