Granite Island Overhang With No Support HELP!!!! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-29-2007, 05:18 AM   #1
Granite Island Overhang with no support HELP!!!!
I am building a new home and think the builder has made a royal mess with the granite island. We have an overhang of 16 inches with NO support. From all I can find on the web, this is dangerous and can crack off. Does anyone know about this kind of thing?
BabyBear is offline   Reply With Quote
Old 09-29-2007, 01:30 PM   #2
Yeppers.......... it'll crack or break... with no support.............
mdlbldrmatt135 is offline   Reply With Quote
Old 09-29-2007, 02:53 PM   #3
Even if the overhang were only 12"s, I would still add wooden brackets. Don't risk losing your granite.
Go buy a set you like and hand them to the builder. This site has a couple of good lookings, also look at other cabinet shops for options.
http://tylermorriswoodworking.com/Wood_Shelves.cfm
97catintenn is offline   Reply With Quote
Old 10-02-2007, 08:42 PM   #4
remodeling pro
Where did he ever find a granite fabricator that would even install that much unsupported overhang? Ten inches max in my opinion. Follow earlier suggestion,and get some type of brackets or corbels under there.
troubleseeker is offline   Reply With Quote
Old 10-02-2007, 10:33 PM   #5
robertcdf's Avatar
I have seen around 12" I did not mesure... It may have been more and that counter was plenty strong. Seen the guys kids sit on it without ever cracking it. But it was also one hell of a thick slab
robertcdf is offline   Reply With Quote
Old 10-02-2007, 10:36 PM   #6
If babybear posts pictures of the over hang, then we can all say that we have seen granite with a 16" overhang.
Old 10-06-2007, 04:57 PM   #7
remodeling pro
Twelve is doable with the full 3cm slabs that most of the stone suppliers in my area are using now, but i still plan on some support because you never know what the grain in the particular slab will be, and a eak vein in the wrong place an be disasterous.
Old 10-08-2007, 01:17 AM   #8
I have done overhangs with 1/4" x 1" steel strap set into a groove that I route into the plywood sub-top....I drill and countersink holes in the steel then screw it to the plywood from the top side, before the granite goes in. I suppose there is a slim possibility that this was done in your case and you don't know. It is invisible after the install, which is the reason I did it.
send_it_all is offline   Reply With Quote
Old 10-08-2007, 11:46 AM   #9
how do I go about replacing a damaged floor joist
donny01709 is offline   Reply With Quote
Old 10-08-2007, 11:47 AM   #10
Old 10-08-2007, 11:55 AM   #11
Multiple Offensive quotes deleted.
Old 10-08-2007, 02:26 PM   #12
zel
Rewards Points: 150
Send a message via AIM to zel
Quote deleted
zel is offline   Reply With Quote
Replacing support beams Annimal76 Remodeling 1 09-10-2007 10:12 AM
How much load can a 20' long 2x8 support? GrdLock Building & Construction 9 06-29-2007 11:15 AM
Decorative Etched Granite Listello csteinke Remodeling 1 06-08-2007 11:54 PM
Need help with basement support jaw522 Building & Construction 3 10-25-2006 08:55 AM
