-   General Discussion (http://www.diychatroom.com/f2/)
-   -   Granite Island Overhang with no support HELP!!!! (http://www.diychatroom.com/f2/granite-island-overhang-no-support-help-11943/)
BabyBear 09-29-2007 06:18 AM
I am building a new home and think the builder has made a royal mess with the granite island. We have an overhang of 16 inches with NO support. From all I can find on the web, this is dangerous and can crack off. Does anyone know about this kind of thing?
mdlbldrmatt135 09-29-2007 02:30 PM
Yeppers.......... it'll crack or break... with no support.............
97catintenn 09-29-2007 03:53 PM
Even if the overhang were only 12"s, I would still add wooden brackets. Don't risk losing your granite.
Go buy a set you like and hand them to the builder. This site has a couple of good lookings, also look at other cabinet shops for options.
http://tylermorriswoodworking.com/Wood_Shelves.cfm
troubleseeker 10-02-2007 09:42 PM
Where did he ever find a granite fabricator that would even install that much unsupported overhang?:laughing: Ten inches max in my opinion. Follow earlier suggestion,and get some type of brackets or corbels under there.
robertcdf 10-02-2007 11:33 PM
I have seen around 12" I did not mesure... It may have been more and that counter was plenty strong. Seen the guys kids sit on it without ever cracking it. But it was also one hell of a thick slab
97catintenn 10-02-2007 11:36 PM
If babybear posts pictures of the over hang, then we can all say that we have seen granite with a 16" overhang.
troubleseeker 10-06-2007 05:57 PM
Twelve is doable with the full 3cm slabs that most of the stone suppliers in my area are using now, but i still plan on some support because you never know what the grain in the particular slab will be, and a eak vein in the wrong place an be disasterous.
send_it_all 10-08-2007 02:17 AM
I have done overhangs with 1/4" x 1" steel strap set into a groove that I route into the plywood sub-top....I drill and countersink holes in the steel then screw it to the plywood from the top side, before the granite goes in. I suppose there is a slim possibility that this was done in your case and you don't know. It is invisible after the install, which is the reason I did it.
donny01709 10-08-2007 12:46 PM
how do I go about replacing a damaged floor joist
donny01709 10-08-2007 12:47 PM
:eek:
donny01709 10-08-2007 12:55 PM
Multiple Offensive quotes deleted.
zel 10-08-2007 03:26 PM
Quote deleted
