I am building a new home and think the builder has made a royal mess with the granite island. We have an overhang of 16 inches with NO support. From all I can find on the web, this is dangerous and can crack off. Does anyone know about this kind of thing?
Where did he ever find a granite fabricator that would even install that much unsupported overhang?:laughing: Ten inches max in my opinion. Follow earlier suggestion,and get some type of brackets or corbels under there.
I have seen around 12" I did not mesure... It may have been more and that counter was plenty strong. Seen the guys kids sit on it without ever cracking it. But it was also one hell of a thick slab
Twelve is doable with the full 3cm slabs that most of the stone suppliers in my area are using now, but i still plan on some support because you never know what the grain in the particular slab will be, and a eak vein in the wrong place an be disasterous.
I have done overhangs with 1/4" x 1" steel strap set into a groove that I route into the plywood sub-top....I drill and countersink holes in the steel then screw it to the plywood from the top side, before the granite goes in. I suppose there is a slim possibility that this was done in your case and you don't know. It is invisible after the install, which is the reason I did it.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
