Granite Counter Top Installation Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-12-2009, 03:57 PM   #1
Granite counter top installation question
I had a L shaped countertop installed and am not sure it was done correctly. The walls were not straight so the hangover is 2" on one end and 1" on the other. There is also a gap between the wall and the top on the 2" end. Is this correct or should the granite have been cut exactly to spec.
Howdyall is offline   Reply With Quote
Old 10-12-2009, 06:29 PM   #2
Rewards Points: 1,016
Does not sound good - got pictures to help understanding?
Old 10-12-2009, 07:01 PM   #3
Residential Contractor
As a remodeler, I deal with granite issues all the time. As the previous poster said, pictures would help.
Do you remember at the templating appointment if a template was made, or if the fabricator just took measurements.
Many times the fabricator will take the easy way out and just measure, which is ok if the walls are square. (They never are)
Your overhangs should all be about 1-1/2". If they are off that much, then something is quite possibly wrong.
rselectric1 is offline   Reply With Quote
Old 10-12-2009, 07:29 PM   #4
DIY staff
Rewards Points: 7,174
Very tactfully said,RSELECTRIC,,,,,,,,,,,,,,,,
Old 10-12-2009, 07:35 PM   #5
Old School
Willie T's Avatar
A heck of a lot more tactful than I would have been. Granite is EXPENSIVE !!!
Willie T
Old 10-12-2009, 07:41 PM   #6
In fairness to the fabricator, lets get all the facts before when say "go get 'em"
Several things could have gone wrong here.
Basically more info is needed.
Old 10-13-2009, 07:12 AM   #7
Thanks for the info and I will post pictures
The fabricator only measured.
Old 10-14-2009, 12:27 AM   #8
newbie
altering is doable
If you have a backsplash and the wall behind is drywall then with a bit of effort, remove splash and recess granite back edge into wall until centered. But it's work!!!
elkwd7 is offline   Reply With Quote
Old 10-14-2009, 09:03 AM   #9
Rewards Points: 5,336
Unless this was done for free, by your brother in law, it sounds like a half assed job.
You should have asked questions at the showroom about the process before you signed up for the job. Any competant fabricator would have templated the counter.
You can post pictures for possible fixes.
Ron
Granite counter best practice or sham? kdh1234 Remodeling 2 08-07-2009 06:18 AM
Sealing a new granite counter top .. (products?) Flt_Simulation Building & Construction 3 07-31-2009 05:48 PM
Vinyl floor + granite counter = Duraceramic floor? hanshananigan Remodeling 3 04-07-2009 09:46 PM
installing granite counter tops dnassif Remodeling 4 07-01-2006 08:37 AM
granite counter top cutting trifit1 Remodeling 2 02-12-2006 06:56 PM
