Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-08-2011, 03:43 PM   #1
Granite..
Greetings folks, what are the pros and cons of using pre-fabrication vs regular slab/fabrication?
I've noticed pre-fab is WAAAAAY cheaper, why is that?
Irvo is offline   Reply With Quote
Old 02-08-2011, 07:45 PM   #2
Tileguy
Bud Cline's Avatar
Granite..
Because it isn't real first class granite and it is usually thinner.
Old 02-09-2011, 10:21 AM   #3
Granite..
Is it really noticeable to the untrained eye?
Old 02-09-2011, 12:24 PM   #4
Granite..
There are a variety of thicknesses of prefab granite available. The supplier I use sells true 1 inch thick slabs finished 3 sides and ~25" x 8'. Others in the area sell nominally 1cm thick granite and then double up the edge with epoxy and run a bullnose.
B
b_corwin is offline   Reply With Quote
Old 02-09-2011, 04:43 PM   #5
Tileguy
Bud Cline's Avatar
Granite..
No it is not!
You hit that right on the head. The key phrase there is "untrained eye". This is what home centers rely on when selling sub-standard products. They know the general public has no idea when it comes to lower quality products and they can sell them at a discount from the first-run products to make you think you are getting a deal when in fact you are only getting what you are paying for. Low quality.
BUYER BEWARE!
Old 02-09-2011, 04:55 PM   #6
Moderator
Termite's Avatar
Granite..
Bud nailed it.
Old 02-09-2011, 05:08 PM   #7
Tileguy
Bud Cline's Avatar
Granite..
Irvo,
If you are one of those people that are inclined to make such purchases (and there is nothing wrong with that) then you are exactly what the home centers are looking for when it comes to loyal customers. Just keep in mind, you may fool your neighbors but you aren't going to fool that stone.
Good Luck.
Old 02-09-2011, 05:43 PM   #8
Granite..
I would say the pros vs. cons is a price vs. quality debate.
Pre-fab granite is thinner, so it tends to crack easier and discolor more. Full slab is thicker, so that extra density makes its more durable (but not unbreakable) which also makes it a little more expensive.
I think it's up to you which way you want to go, but if your granite cracks or chips, finding an exact color match in another piece of granite can be difficult.
MsMatthews is offline   Reply With Quote
Is this a lousy granite installation? timbo59 Kitchen & Bath Remodeling 70 05-16-2013 11:08 PM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 05:54 PM
Granite Hearth/Saltillo tile transtion help SeminoleMike Flooring 2 02-08-2009 12:49 PM
Granite not installed correctly???? debsc Kitchen & Bath Remodeling 7 02-01-2009 09:58 AM
