Grab It Or Run Like Hxxx? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-23-2009, 10:50 AM   #1
Rewards Points: 91
grab it or run like hxxx?
I have the opportunity to pick up a powermate compressor. specs are 2 cyl, belt drive, 20 gallon, 155psi max, castiron - oil lubricated, 7.0 cfm@40 psi, 5.7 cfm @90 psi, 1.9 rhp and 120 volt. It's close to 1/2 price. The problem is that there is a small hole in the tank and it is out of warranty. This is the dealer selling it. I have not seen it. The dealer has described it as "usable."
I have one huge job - remove the mortar from 1000 bricks then i have no use for the compressor.
1. would you grab it or run like hell?
2. is it possible to stick some epoxy into the hole?
3. I have to assume that there is no way to weld the tank once it is in use.
Comments, opinions, experiences?
Allthunbs
Allthunbs is offline   Reply With Quote
Old 06-23-2009, 11:59 AM   #2
47_47's Avatar
Rewards Points: 58
I wouldn't buy an air compressor with a bad tank, unless I had one like it (spare parts). Can't you rent a compressor for your brick job?
47_47 is online now   Reply With Quote
Old 06-23-2009, 12:02 PM   #3
Rewards Points: 91
Hi 47 47:
Thanks for the reply. Nope, it's cheaper to buy than to rent.
Old 06-23-2009, 12:07 PM   #4
I'd have to see it 1st
I think these are usually pressure tested?
I'm not sure of the safety factor on one with a hole?
I know my scuba tanks are rated much higher then the actual fill
I'm surprised he would sell it as it may be a liability issue if anything goes wrong ?
