Grab Bars - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-21-2012, 07:48 AM   #1
Rewards Points: 6,034
Grab bars
Went today to install some grab bars for a lady whose husband is coming home from rehab after breaking a hip. She wanted to install a grab bar by the commode and 1 in the shower. Shower, no problem found the studs, pretty straight forward. By the commode, different story, it is a cement block wall that separates the 2 condos. So now all you have is 1/2" drywall and a 1x furring strip then the block wall. This gives you 1 1/4" of useless space as the drywall or the 1x have no holding power how would you mount this bar? Oh and the man is 6'2" over 200# not a little guy.
Old 12-21-2012, 08:50 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 772
Some folks use the Tapcon screws but they are a little pricey. I have drilled a hole the same size as the screw threads in the wood and on into the concrete wall. Take a #12 electric solid wire strand, leave the insulation on the wire, insert the wire in the hole then screw the bar to the wall. You can not pull it off the wall.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (12-22-2012)
Old 12-21-2012, 08:55 AM   #3
Rewards Points: 14,300
Can you find the furring strips? If so then your stuck with using 3" long Tap Cons.
Old 12-21-2012, 08:57 AM   #4
I thought of that Jim but was a little leery of the Tapcons because they are so brittle. Remember this is a big man.
Old 12-21-2012, 08:58 AM   #5
DIY staff
Rewards Points: 7,174
Good news/bad news-----open up the drywall----add solid blocking---replace the drywall---then use Tapcons or that copper wire (I like that idea) and repaint the bathroom.
This is a life threatening failure if your work fails because the grab is installed over a void----these aren't decorative do dads---a fragile big guy will be relying on them to hold his weight---
More work,yes---so charge for it----
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
BigJim (12-21-2012), mae-ling (12-21-2012)
Old 12-21-2012, 09:10 AM   #6
ok add solid backing still has to be 1x stock and the Tapcon have to be the smallest ones to fit in the holes in the bar.
Old 12-21-2012, 09:13 AM   #7
DIY staff
Yep--or drill out the holes to accept a larger screw---
Old 12-21-2012, 10:32 AM   #8
Can't drill no room .
Old 12-21-2012, 03:52 PM   #9
Rewards Points: 1,092
Perhaps.... Custom grab bars, w/ a 4" diam fixing plate with 4 holes for TapCons and tapped for small machine screws; as mentioned, this is serious. Make wooden discs that cover the fixing plates of the grab bars, secured (eventually) to the fixing plate. Cut the sheetrock. Insert the grab bar flush to the concrete. TapCon the H out of them. Install wooden discs, screwing them to the fixing plates. Plug the holes in the sheet rock. Yes, very expensive; so is falling, esp for YOU.
Old 12-22-2012, 08:56 AM   #10
Rewards Points: 240
thats it right there. you gotta make it strong enough to pull a car, literally.
Fix'n it is offline   Reply With Quote
Old 12-22-2012, 09:00 AM   #11
The fact that tap cons are so brittle and the heads snap off so easy is not a problem.
Old 12-22-2012, 04:34 PM   #12
Rewards Points: 105
They have some new heavy duty anchors for TV mounts that can hold 200lb tv's. Maybe you can double that up instead of the tap-cons.
Just a thought.
Sent from my iPhone using DIY Forum
jdm001 is offline   Reply With Quote
Old 12-22-2012, 04:50 PM   #13
DIY staff
That method Jim mentioned is safe---drill pilot holes through the board and brick---add an anchor (the copper wire) and send those long coarse screws into it---You will have a good strong and safe grab bar---
I installed nearly 200 grab bars in the last two or three months---You will be quite safe in my opinion.
BigJim (12-22-2012), ToolSeeker (12-23-2012)
Old 12-23-2012, 04:03 PM   #14
Rewards Points: 183
Forget about installing the grab bars to that wall. Instead get a bar made for the toilet.
http://www.1800wheelchair.com/produc...FQRnOgodMRsAZA
They are easy to install and to remove at a later time. I have installed them on a few toilets and they work great
paul100 is offline   Reply With Quote
tub or wall bars for bathtub grandmeme Plumbing 7 06-13-2012 07:29 PM
Basement Window Security Bars frede Concrete, Stone & Masonry 6 05-14-2012 01:31 AM
Gluing backers in fiberglass/acrylic shower for grab bars jocalmu General DIY Discussions 1 02-27-2010 01:22 PM
Where does my question go? Grab bars in bathrooms Galadriel General DIY Discussions 6 02-19-2010 11:20 AM
Power Grab "glue"??? SillySally Remodeling 14 08-29-2009 11:29 AM
