-   -   Grab bars (http://www.diychatroom.com/f2/grab-bars-167054/)
ToolSeeker 12-21-2012 08:48 AM
Grab bars
Went today to install some grab bars for a lady whose husband is coming home from rehab after breaking a hip. She wanted to install a grab bar by the commode and 1 in the shower. Shower, no problem found the studs, pretty straight forward. By the commode, different story, it is a cement block wall that separates the 2 condos. So now all you have is 1/2" drywall and a 1x furring strip then the block wall. This gives you 1 1/4" of useless space as the drywall or the 1x have no holding power how would you mount this bar? Oh and the man is 6'2" over 200# not a little guy.
BigJim 12-21-2012 09:50 AM
Some folks use the Tapcon screws but they are a little pricey. I have drilled a hole the same size as the screw threads in the wood and on into the concrete wall. Take a #12 electric solid wire strand, leave the insulation on the wire, insert the wire in the hole then screw the bar to the wall. You can not pull it off the wall.
joecaption 12-21-2012 09:55 AM
Can you find the furring strips? If so then your stuck with using 3" long Tap Cons.
ToolSeeker 12-21-2012 09:57 AM
I thought of that Jim but was a little leery of the Tapcons because they are so brittle. Remember this is a big man.
oh'mike 12-21-2012 09:58 AM
Good news/bad news-----open up the drywall----add solid blocking---replace the drywall---then use Tapcons or that copper wire (I like that idea) and repaint the bathroom.
This is a life threatening failure if your work fails because the grab is installed over a void----these aren't decorative do dads---a fragile big guy will be relying on them to hold his weight---
More work,yes---so charge for it----
ToolSeeker 12-21-2012 10:10 AM
ok add solid backing still has to be 1x stock and the Tapcon have to be the smallest ones to fit in the holes in the bar.
oh'mike 12-21-2012 10:13 AM
Yep--or drill out the holes to accept a larger screw---
ToolSeeker 12-21-2012 11:32 AM
Can't drill no room .
jklingel 12-21-2012 04:52 PM
Perhaps.... Custom grab bars, w/ a 4" diam fixing plate with 4 holes for TapCons and tapped for small machine screws; as mentioned, this is serious. Make wooden discs that cover the fixing plates of the grab bars, secured (eventually) to the fixing plate. Cut the sheetrock. Insert the grab bar flush to the concrete. TapCon the H out of them. Install wooden discs, screwing them to the fixing plates. Plug the holes in the sheet rock. Yes, very expensive; so is falling, esp for YOU.
Fix'n it 12-22-2012 09:56 AM
thats it right there. you gotta make it strong enough to pull a car, literally.
ToolSeeker 12-22-2012 10:00 AM
The fact that tap cons are so brittle and the heads snap off so easy is not a problem.
jdm001 12-22-2012 05:34 PM
They have some new heavy duty anchors for TV mounts that can hold 200lb tv's. Maybe you can double that up instead of the tap-cons.
Just a thought.
Sent from my iPhone using DIY Forum
oh'mike 12-22-2012 05:50 PM
That method Jim mentioned is safe---drill pilot holes through the board and brick---add an anchor (the copper wire) and send those long coarse screws into it---You will have a good strong and safe grab bar---
I installed nearly 200 grab bars in the last two or three months---You will be quite safe in my opinion.
paul100 12-23-2012 05:03 PM
Forget about installing the grab bars to that wall. Instead get a bar made for the toilet.
http://www.1800wheelchair.com/produc...FQRnOgodMRsAZA
They are easy to install and to remove at a later time. I have installed them on a few toilets and they work great
