Good Tarp For DIY Slip N Slide? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 12:47 PM   #1
Rewards Points: 14
Good tarp for DIY Slip n Slide?
I'm looking to build my own slip n slide about 40 feet long and 8 feet wide (doesn't need to be exact).
Instead of buying a couple cheap slip n slides that will likely tear after a few uses and gluing them together, I thought it might be better to just purchase a strong tarp.
It will just need to be smooth, slipery, and durable.
What type of tarp would you recomend for a good slip n slide?
Thanks!
ffrllc is offline   Reply With Quote
Old 07-25-2011, 02:45 PM   #2
Rewards Points: 6,652
Heavy black plastic will work.
The Following User Says Thank You to gregzoll For This Useful Post:
ffrllc (07-25-2011)
Old 07-25-2011, 03:04 PM   #3
Rewards Points: 150
use lots of dishsoap to make it extra slippy.....
sbmfj is offline   Reply With Quote
The Following User Says Thank You to sbmfj For This Useful Post:
ffrllc (07-25-2011)
Old 07-25-2011, 03:12 PM   #4
I think I'd look for a roll of heavy 20 mil or so vinyl.
GottaFixIt is offline   Reply With Quote
The Following User Says Thank You to GottaFixIt For This Useful Post:
ffrllc (07-25-2011)
Old 07-25-2011, 04:19 PM   #5
kwikfishron's Avatar
Rewards Points: 576
Looks like plastic works pretty well.
kwikfishron is offline   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
ffrllc (07-25-2011), gma2rjc (07-25-2011)
Old 07-25-2011, 04:42 PM   #6
KemoSabe
loneframer's Avatar
Use KY Jelly and set some land speed records.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
The Following User Says Thank You to loneframer For This Useful Post:
ffrllc (07-25-2011)
Old 07-25-2011, 11:18 PM   #7
Rewards Points: 14
Thanks for the replies guys,
No other way to ask this without sounding stupid, but what type of plastic tarp (or what type of vinyl as someone suggested) would you use for a slip n slide? There are many...some are rough, some are too thick, too thin...etc...
Links to the type would help
Old 07-26-2011, 09:02 AM   #8
A tarp will not work, but heavy 20 mil black plastic will. It is the same type used out at our church camp for a slip & slide.
ffrllc (07-26-2011)
Old 07-26-2011, 09:49 AM   #9
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Just call your local contractor supply house and ask if they carry Visqueen. 10-20 mil thick is gonna last, but it's also going to be pricey.
If you want to experiment on the cheap, you can get 6 mil just about anywhere. a 10'x100' of 6 mil roll would probably cost about $50 and you should be able to find it a depot, & lowes, as well as local hardware and lumber yards
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
The Following User Says Thank You to Mr Chips For This Useful Post:
ffrllc (07-26-2011)
PVC Slip coupler msaeger Plumbing 5 03-13-2011 09:46 PM
Best way to tarp roof? jogr Roofing/Siding 3 06-05-2009 02:34 PM
